Benzine
| posted on 10/6/10 at 07:04 PM |
What to do with supercharger
I have an Eaton M62. I bought it second hand but it was new, I've used it for about a minute in total. The problem is that something got into it
before I used it, swarf/grit or something and now it's got some scratches on the rotors.
What are my options? Can it be repaired? How much difference will having a few scratches make?
Does anyone want to buy a supercharger?
Scratches
Ben_Copeland
| posted on 10/6/10 at 07:10 PM |
Give ya a tenner for it
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
big_wasa
| posted on 10/6/10 at 07:12 PM |
twenty
The blades are coated, I doubt there is any thing you can do. Just run it and suck it and see.
[Edited on 10/6/10 by big_wasa]
eddie99
I'll give you £25
[Edited on 10/6/10 by eddie99]
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
| posted on 10/6/10 at 07:16 PM |
It'll make a small difference because the Eaton has coated blades so they can run at close tolerances. you'll inevitable loose a bit of
boost with scratches like those. But probably not a lot!!!
I must admit the M45 that I bought had similar ones. It's hardly surprising- the air gap between the rotas is so small, even the smallest bit of
fine grity dust will do it.
Eaton probably could re-coat the blades but I expect it would be cheaper to just get a new one!!!!
eddie99
Actually i say chuck it on the bay as a codename starting at 99p and U2U me the link. That'll do just fine.
iank
| posted on 10/6/10 at 07:21 PM |
Don't some eaton's suffer from the blade coating's peeling off (some of the MINI ones do iirc). If so then those scratches may
cause the coating to peel and be ingested by the engine.
I'd call Eaton and talk to them about your options.
Anonymous
Stuart_B
| posted on 10/6/10 at 07:32 PM |
they do replacement rotors.
i saw a set on ebay the other day brand new.
when i look for supercharges, enough idea what i will not get insured on.lol
stuart
tegwin
| posted on 10/6/10 at 10:03 PM |
Being a bit of a "bodge and see" kinda guy... provided the damage was nothing major I would strip out the scrolls and carefully
file/polish off any raised lips etc.. and re-assemble and then use it with more care next time!!
www.verticalhorizonsmedia.tv
Benzine
| posted on 11/6/10 at 07:40 AM |
Thanks for the info everyone
£200 if anyone wants it, I paid more than double that. It's got uprated bearings too.
