omega0684
| posted on 24/6/10 at 10:40 AM |
Swirl pot questions
Hi Guys,
I turn to the forum for insite and advice,
i am installing a Swirl pot system as a back up to stop any surging.
i have a couple of questions,
1) does it matter how far the swirl pot is from the low pressure pump? By the looks of things at the moment i am going to have the LP Pump @ the back
of the car and the swirl pot in the front,
2) What is a good size to go for? at the moment i have designed a tank that will hold between 1.2 - 1.5 litres, is this enough?
3) the inlet (from LP Pump), the inlet (from the fuel rail) and the return to the tank are all JIC -6 (8mm). the inlet to the HP Pump at the moment
has a JIC -8 fitting (12.7mm).
shall i stick with the JIC-8 fitting on the HP Pump and have a JIC-8 outlet put on the swirl pot or shall i change to a JIC-6 fitting on the HP Pump
inlet and have a JIC-6 outlet on the swirl pot or does it not matter?
All advice welcome
l0rd
| posted on 24/6/10 at 12:13 PM |
Personaly, I would have it as close to the tank as i can get it. Remember it is a LP pump. I would leave the HP pump do the rest.
But that is me.
mad4x4
| posted on 24/6/10 at 12:22 PM |
Mine is under the bonnet next to the Throttle Bodies, So I didn't loose more boot space... even though |I already have zero.
Scot's do it better in Kilts.
bob tatt
| posted on 24/6/10 at 03:03 PM |
mine is set up with the lp pump in the back with the swirl pot under the bonnet feeding the hp pump and fuel rail. As for the connection sizes id get
leave it well alone and let the hp have as much fule as poss its that size for a reason..
