cadebytiger
posted on 29/6/10 at 02:50 PM |
BMW steering lock
Sorry it's not locost
A friend of mine is having some trouble with the steering lock on his BMW 1 series. It occasionally does not switch off and the dash usefully tells
him that there is a problem with it. lol
Anyone had this problem or know anything about it?
Thanks again
Rupert
posted on 29/6/10 at 03:01 PM |
Interesting. Looks like he's not the first to experience the problem...
http://www.babybmw.net/forum/viewtopic.php?f=3&t=15254
jossey
posted on 29/6/10 at 03:03 PM |
its a common fault. if he goes to a bmw specialist. NOT a dealer cos they charge tons then you can get an update to stop it. its around £30 ish to get
update.
i pressume the fault light is in yellow not red?
cheers
cadebytiger
posted on 29/6/10 at 03:05 PM |
Oh thanks Ben - does not looks great -
cadebytiger
posted on 29/6/10 at 03:10 PM |
update.
cheers
Just spoke to him again and it is sometimes yellow sometimes red... Does red mean new mechanism??
Unfortunately it is at a main dealer now being 'diagnosed'
posted on 29/6/10 at 03:12 PM |
Personally I'd take it to a main dealer and tell them it's a POS and they have to mend it ASAP as it's not fit for purpose and try
it on that way! If all it needs is a software upgrade then that's an admission that the software doesn't work IE not fit for purpose. QED.
jossey
posted on 29/6/10 at 03:29 PM |
from the large experience ive had with main dealers after its past the warranty then its a pain for them to fix anything even if its proved to be a
common fault.
good luck to him getting it fixed.
the yellow is a common fault the red not so much.
good luck i know they charge a bundle.
525D 2005 150,000 miles later i found out the hard way.
cadebytiger
posted on 29/6/10 at 03:37 PM |
Thanks for the help
At least if they try and charge him a massive diagnostic fee he can say that it is a common fault and that is should not take long to diagnose a
common fault ..... lets hope they are reasonable!
