Irony
posted on 30/6/10 at 08:15 AM |
The making of brackets
I have been making a plastic template for a alternator bracket I need. I was going to get the shape perfect and then cut it from 5 - 6mm ally. On
mentioning this to friend of mine he said 'oh ally will snap, it needs to be out of steel'.
Will aluminium snap and should I make the bracket from steel? Should all brackets be make from Steel?
JeffHs
posted on 30/6/10 at 08:19 AM |
I agree with your friend. The tight bends needed to make nice brackets will break in no time if made from ali.
Irony
posted on 30/6/10 at 08:22 AM |
^^^ I agree with that after having tried to cold bend ally bar to a right angle. You can see it fracturing as you bend it. But my Alternator
bracket is flat and just a funny shape.
iank
Tight bend, and 5-6mm ally
If it's just a flat plate with bolt holes (i.e. no bends) then ally will be fine and at 6mm won't fail.
Thin strip aluminium with bends will fail quickly if it's carrying any load and vibrates.
ETA: People make brake caliper brackets from aluminium.
[Edited on 30/6/10 by iank]
Anonymous
posted on 30/6/10 at 08:27 AM |
6mm ali is quite strong stuff- I made my throttle pot spacer plate out of it and couldn't bend it despite trying (for various reasons).
It's also much nicer to work with.
Just be careful with the filings if you've got ali filings and old (rusty) iron filings all mixed up on the floor.
Irony
posted on 30/6/10 at 08:33 AM |
It is just flat plate with bolt holes essentially! Why would mixed filings cause a problem?
smart51
posted on 30/6/10 at 08:37 AM |
Kaboom! Remember the Hindenburg? it set on fire because it was coated in an emulsion of aluminium powder and iron oxide powders. Static discharge
on landing caused a spark that ignited it and Kaboom! This mixture is called Thermite and is now used as solid rocket fuel.
sucksqueezebangblow
posted on 30/6/10 at 08:43 AM |
A good approach would be to bend it progressively 5 or 10 degrees at a time and annealing it each time by rubbing soap on it and heating the bend
until the soap goes black.
eddie99
posted on 30/6/10 at 08:46 AM |
I think 6mm Ally would be suitable, i've used it on a few occasions and its extremely strong.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Irony
posted on 30/6/10 at 08:47 AM |
Oh dear. The things you learn. Just googled it as well. Seems a Thermite reaction could be produced. Good job I do most of that work outside and
clean up regularly then! Back to brackets.......
[Edited on 30/6/10 by Irony]
loggyboy
posted on 30/6/10 at 09:05 AM |
Is this a mouting bracket or an adjustment bracket?
Irony
posted on 30/6/10 at 09:21 AM |
The adjustment bracket. The mounting is the original cast ali bracket and I need to make a bracket that adjusts the tension. The original one is
steel flat bar. But I was going to make a ali one.
40inches
posted on 30/6/10 at 09:45 AM |
Will be OK if using 6082 (H30) grade as
here,you may get it cheaper elsewhere.
