nearly done
posted on 1/7/10 at 08:17 PM |
filter king fuel pressure regulator
evening all,
am I right that in thinking that you wind the adjuster in to decrease the fuel pressure.Any pointers greatly received.
Thanks,Sean
posted on 1/7/10 at 08:29 PM |
Wind it out, I believe - like most regulators.
prawnabie
posted on 1/7/10 at 08:34 PM |
Where abouts are you, i have a pressure gauge if you want to borrow it.
Shaun
posted on 2/7/10 at 07:09 AM |
pretty sure DJ is correct. there is a spring loaded diaphragm (try spelling that when yer pissed!) so by turning the screwn clockwise (i.e. doing up)
you compress the spring which applies more pressure to the diaphragm (try spelling that correctly twice when in a hurry).
The net result is that the fuel needs to be at a higher pressure to get past the diaphragm (did I spell it correct that time? stupid word , must
be French :mad .
nearly done
posted on 3/7/10 at 04:13 PM |
cheers guys,best unwind that nut then or the bike carbs will be spilling fuel.
