r1_pete
| posted on 4/7/10 at 08:30 PM |
Diesel advice Needed
Daugter and husband just came round, with Diesel pi$$ing out of the return pipe on his Astra Mk4, its a 12mm pipe which opens up to 20mm for the push
on fitting, pipe had split on the flare.
To keep it on the road short term, I spun a 12 - 20mm reducer up, cut the split bit of pipe off, but, the only pipe I had in 20mm bore, was heater
hose, question is, how unfriendly is diesel to 'rubber' heater type hose?
I know its temporary till I can get some 20mm fuel hose, just wondering how temporary it needs to be?
Cheers.
Pete.
[Edited on 4/7/10 by r1_pete]
| posted on 4/7/10 at 08:33 PM |
Cheers.
Pete.
Till it starts pissing diesel
Most of my temporary repairs have last until they failed
r1_pete
| posted on 4/7/10 at 08:35 PM |
Steve Hignett
| posted on 4/7/10 at 08:44 PM |
Quick search...
http://answers.yahoo.com/question/index?qid=20100311203954AAHyKAo
Ninehigh
| posted on 4/7/10 at 08:55 PM |
Haven't there been complaints about petrol hose dissolving at a random point? Sounds like a "get some asap, but no need to get it RIGHT
NOW!" case
Dingz
| posted on 4/7/10 at 09:22 PM |
Depends what the heater hose is made from, if it is nitrile rubber it will be fine with diesel (not with unleaded petrol tho) but I think most heater
hose will be EPDM which will swell and go soft fairly quickly.
went on and on.
dinosaurjuice
| posted on 4/7/10 at 09:49 PM |
not sure without seeing hose spec, but after youve replaced with proper stuff change the fuel filter after a few hudnred miles. just in case its
gummed up with dissolved gloopey rubber.
