mcerd1
posted on 5/7/10 at 10:48 PM |
Tin-Top - help! (focus)
following this earlier: http://www.locostbuilders.co.uk/viewthread.php?tid=139189
I've just done the wheel bearing with only a couple of bolts giving me hassle - but as soon as put the wheel back on the disc jams against the
caliper carrier
I can't see anything wrong with how its put together so now I'm stuck
any ideas ? (btw its a mk1 focus without ABS)
Mark G
posted on 6/7/10 at 06:10 AM |
I don't know the setup of focus bearings, but it sounds to me like the bearing either isn't fully pressed in or you've been supplied
the wrong part.
adithorp
posted on 6/7/10 at 06:54 AM |
After you'd pressed the bearing into the carrier did you press the flange into the bearing? If it's not fully home then thats the result
you'd get.
adrian
http://jpsc.org.uk/forum/
mcerd1
posted on 6/7/10 at 07:11 AM |
The bearing is fully pressed in (there is a circlip that holds it) and the hub is fully pressed into the centre.....
posted on 6/7/10 at 07:21 AM |
Wheel bearing fitted wrong way round ?
mcerd1
posted on 6/7/10 at 07:22 AM |
they are the same both ways round.....
l0rd
posted on 6/7/10 at 07:34 AM |
Disc inserted the wrong way round?
Silly suggestion but you never know.
mcerd1
posted on 6/7/10 at 07:42 AM |
the disc is the right way round...
it looks like its actually slightly too far on - but I can't see how it could be
mcerd1
posted on 6/7/10 at 08:26 AM |
just had a call from my dad, he recons one of the pad guide bits is bent
dinosaurjuice
posted on 6/7/10 at 08:37 AM |
any chance of a picture?
mcerd1
posted on 6/7/10 at 09:03 AM |
not for a while I'm stuck at work
Danozeman
posted on 6/7/10 at 10:07 AM |
Pad guides bent?? Did you press it out with the hub supported on the mounting lugs for the caliper?
Dan
mcerd1
posted on 6/7/10 at 11:07 AM |
for about 1 second with hardly any force (didn't even regester on the gauge)
then decided that they wern't strong enough and changed the supports - but I guess that was already too late
posted on 6/7/10 at 02:50 PM |
Usually they have a very subtle difference, on front wheel drives the internal bore of the bearing usually has a more generous radius where it
meets one face.
mcerd1
posted on 6/7/10 at 06:40 PM |
meets one face.
don't remember and difference at all - but I'll look out for it the next time
