| posted on 8/7/10 at 01:33 PM |
towbar + fitting cost?
What sort of money is it get a tow bar fitted and wired up...?
Passat mk6 estate
Danozeman
| posted on 8/7/10 at 01:47 PM |
about 300 at indespension for one of them. Get the bar and vehicle specific wiring kit and do it yourself. Theyr easy and not expensive off ebay.
Try towequip.
Dan
| posted on 8/7/10 at 01:53 PM |
Thanks Dan
Do the DIY kits come with a template for any drilling?
Do you actually need to drill any holes these days or is a bolt on affair...?
Slater
I got my 2007 Passat fitted with standard towbar for £326, the car has cambus wiring so needs a special box to get the wiring to work.
GMPMotorsport
| posted on 8/7/10 at 02:01 PM |
Easy enough to DIY, comes with instructions, usually the worst thing you need to do is drop the bumper but that depends on the car, have a look on Tow
Sure web site I think they have all of the instructions on there so look before you buy.
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
spdpug98
| posted on 8/7/10 at 02:07 PM |
Could try Towsure down in Southampton, they have fitted towbars to my last few cars and tend to be a good bit cheaper than Indespension
My Blog: http://spdpug98.wordpress.com/
| posted on 8/7/10 at 02:15 PM |
Go down the scrappy and find one, then you can take it off, see how its fitted, and pay £40.
You builds a car so fit the thing yourself!
ReMan
| posted on 8/7/10 at 02:48 PM |
Just done the Saab, toweqipe for less than £100 inclunding ball and wiring.
£25 for the relay box if its got modulated lights with fail warnings etc
Danozeman
| posted on 8/7/10 at 04:34 PM |
I doubt youd get a MK6 one from a scrappy just yet.
No holes mate. You take the bumper off, unbolt the crash bar and the tow bar bolts in its place.
Here are the instructions for a later passat.
Here are the bars
I think you have to speak to them for the wiring kit. If you get vehicle specific it will just plug in. All you need to do i think is then run a
feed from the battery.
Get westfalia if you can theyr genuine vw fitted things.
Dan
| posted on 8/7/10 at 04:47 PM |
Top replies chaps - cheers!
Already been looking at the Westfalia kit which seems easy enough.
My only hesitation is the fact it's a lease car so it has to go back to standard on return. No holes means that should be simple enough though!
Humbug
| posted on 8/7/10 at 04:54 PM |
The instructions that Danozeman just linked to include cutting the bumper...
| posted on 8/7/10 at 09:18 PM |
place in leeds did my van for £160.
