Author: Subject: Washer pump and fuel...
bigandy
posted on 9/7/10 at 09:07 AM Reply With Quote
Morning all. Would one of the generic washer pumps (the gear type ones, not the vane type ones) be okay to use as a small fuel transfer pump? I'm specifically thinking about using it for petrol and two stroke oil....
[Edited on 9/7/10 by bigandy]
Dammit! Too many decisions....
mistergrumpy
posted on 9/7/10 at 09:21 AM Reply With Quote
I should think that any seals and also the type of plastic used in the gears may not be fuel proof and they'd just turn mushy.
r1_pete
posted on 9/7/10 at 09:22 AM Reply With Quote
You'd be better off with a carbed motorcycle fuel pump, or a car SU type.
Whether the plastic bits and seals in those washer pumps are fuel proof is doubtfull, and you wouldn't want the motor immersed in fuel.
bigandy
posted on 9/7/10 at 09:23 AM Reply With Quote
That's what I was worried about really. I was hoping that somebody might have already tried it, and found it to be okay/not okay.....
A carbed motorbike fuel pump sounds good though. Are they nice and small/light/easy to use?
r1_pete
posted on 9/7/10 at 09:27 AM Reply With Quote
Yes, about 80 - 100mm long 40 or so mm dia, usually 6 or 8mm in and out.
