woolly
| posted on 11/7/10 at 09:57 AM |
laguna help please.
help please from the Renault people. (daughters car)
i am trying to identify the fuel regulator control solenoid.
P0002 P0003 codes
laguna 11 51 plate 1.9 cdi
fault is a hesitation at 2200 revs light load and when loaded inj fault warning comes up. then goes in to limp mode..
as usual it is intermittent.
car starts on the button hot or cold.
any pointers please.
changed fuel & air filter
rail pressure sensor and the valve thing on the end of the rail.
gently played with the wiring at the plugs till the cows came home.
thanks for your time.
woolly
prawnabie
| posted on 11/7/10 at 10:28 AM |
Its a two bolt jobbie on the back of the pump
Danozeman
| posted on 11/7/10 at 05:25 PM |
As prwan says. That is normally a bolt in solenoid at the back of the pump.
They go wrong on a lot of engine. fords especially.
Dan
woolly
| posted on 11/7/10 at 08:20 PM |
thanks for your replies. i will have a go tomorrow.
woolly
prawnabie
| posted on 11/7/10 at 08:49 PM |
Ill have a look round at work to see if I have a working one you can test.
woolly
| posted on 12/7/10 at 06:18 PM |
well
removed the valve and checked the seals all looked ok.
is that as far as i can check it please.
woolly
woolly
| posted on 22/7/10 at 04:08 PM |
back to square one.
been looking for the crank sensor has it even got one ? cleaned the camshaft one
any help please.
woolly
