franky
posted on 18/7/10 at 10:06 PM |
Best putty for a pinhole in a sump?
As above, I've a tiny tiny pinhole in a cast ally sump, What is the best putty type stuff to use?
I take it the best method is to drain the oil out, degrease and key the area?
Ninehigh
posted on 18/7/10 at 10:10 PM |
You know there was an advert for JML sealant putty, looks like that could well do the job once degreased..
UncleFista
posted on 18/7/10 at 10:16 PM |
No need to drain the oil, just bung some soap (from a bar) in the hole, key the surface with an abrasive pad then cover with jbweld/chemical metal
etc.
It's what we did as a temporary measure a year ago as we were a couple of hundred miles from home, and it's still oil-tight now
[Edited on 18/7/10 by UncleFista]
Tony Bond / UncleFista
mark chandler
posted on 18/7/10 at 10:54 PM |
You could try planishing the hole first, get it really clean then tap away with a ball pein hammer.
oadamo
posted on 18/7/10 at 10:58 PM |
couldnt you tap it out and put a small screw with a washer on to seal it. or just use a self tapper.
adam
Daddylonglegs
posted on 19/7/10 at 01:21 AM |
Another vote for JB Weld
stevebubs
posted on 19/7/10 at 08:13 AM |
Halfords do a pritt stick type thing that works well
If you're going to the effort of draining, I would get it brazed...
Strontium Dog
posted on 19/7/10 at 09:52 AM |
Surely someone near you must have an AC TIG welder! If you were near me I'd do it for you happily. Epoxy will never be a permanent solution,
merely a band aid cure!
