RickRick
| posted on 19/7/10 at 11:04 AM |
Scrap astra soft top full of fuel
Whats the best way to get 50L of petrol out of a 1998 astra soft top thing it's going to the scrappers more than likely i have a 12v fuel
pump with some 8mm hose attached to help me
MK9R
| posted on 19/7/10 at 11:05 AM |
lift back seat up and take fuel sender plate out and drop pump/hose in the there.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Miks15
disconnet the hose that goes to the engine, attach your pump on to that and away you go.
loggyboy
| posted on 19/7/10 at 11:10 AM |
Is it an injection?
On the rail there should be what looks like a tyre valve, which is pretty much what it is, so if you have a tyre valve tool you can remove inner
valve, stick a hose over the end, supply 12v to the pump (usually to the right of the tyre well on the underside) and watch the fuel pump it self out.
adithorp
| posted on 19/7/10 at 11:18 AM |
What he said^^^. However if you go in the relay box under the bonnet you should be able to find the fuel pump relay. pull it out and use a piece of
wire with a female lucar connector on each end to by-pass it.
adrian
http://jpsc.org.uk/forum/
Danozeman
| posted on 19/7/10 at 12:01 PM |
As above but you shouldnt have to by pass the relay. The pump will keep going if it doesnt sense a pressure build up. Just turn the ignition on.
Dan
adithorp
| posted on 19/7/10 at 12:06 PM |
The pump stops after a few seconds unless the engine starts.
Davegtst
| posted on 19/7/10 at 12:21 PM |
Easy, disconect the feed to the filter or fuel rail and extend the pipe into a load of cans or another car. Then either lift the back seat and give
the fuel pump a live feed or bridge the fuel pump relay.
Irony
| posted on 19/7/10 at 01:37 PM |
Many moons ago when I was about 17 my then girlfriend drove her car into the ground and melted the pistons due to a water leak. She had just put 60L
in it. I thought, I will do what they do in the movies, I put a piece of hose pipe into the fuel filler and with a bucket tried to syphon the fuel
out. I tried to start the flow by sucking on the pipe.
After the vomiting and retching stopped I decided it wasn't worth it. Youth is wasted on the young.
Dangle_kt
| posted on 19/7/10 at 02:29 PM |
do you have a ramp or pit?
then screwdriver through the bottom of the fuel tank.
PSpirine
| posted on 19/7/10 at 06:52 PM |
Some screwdrivers + steel tank = sparks. Big boom.
| posted on 19/7/10 at 07:04 PM |
my mate burnt his garage down (and half his house) doing this, so take care whatever you do!
| posted on 19/7/10 at 07:23 PM |
Make sure if you use a pit you don't spill any , as well as the fire hazard the fumes are likely to knock you out! Petrol in your eyes is
painful but not compared to petrol in your ear, beware!!!
