Author: Subject: KA... help... with pics
tegwin
posted on 19/7/10 at 03:11 PM Reply With Quote
Still trying to find the cause of the misfire in my sisters KA 1.6 sportka..... Its done 80,000 miles
Very evident at idle but not so noticeable above 3000RPM...
Changed the plugs, HT Leads and coilpack.... also switched around injectors and done a compression test..
Comp test shows nothing out of the ordinary and switching injectors around doesnt help... the problem (according to the diag) is percistantly in Cyl2....
Its not a really bad misfire, but its annoying and I dont want it to suddenly get worse or cause a catastrophic failiure on the motorway or something...
Took the rocker cover off and found a slightly worn camshaft... would this cause a misfire?
I can actually flick the coating on the cam lobes off with my fingernail in places..
What would cause that damage? Any thoughts on what else might be causing my misfire?
[Edited on 19/7/10 by tegwin]
www.verticalhorizonsmedia.tv
MikeR
posted on 19/7/10 at 03:20 PM Reply With Quote
no idea what is causing the damage - but those bits will now be floating around your engine. How big are they - could they block an oil way / cause a problem for a bearing surface?
tegwin
posted on 19/7/10 at 03:22 PM Reply With Quote
Biggest flake I could pull off with a finger was about 2mm long, 2mm wide and about .5mm thick... very brittle stuff....
Deffinately not what you want floating about in the engine!
jossey
posted on 19/7/10 at 03:50 PM Reply With Quote
aint that due to over heating of the cams caused by bad oil normally.
i have seen that on a old Focus.
maybe its a ford thing.
dave j
omega 24 v6
posted on 19/7/10 at 04:31 PM Reply With Quote
could be the cause of your misfire depending on the depth of the holes.
Imagine the scenario where a flake comes off and the cam comes round before the oil press has enough time to pump up the hydralic tappet. ).5mm clearance is quite a bit.
Also as most cams are only surface hardened then IMHO it's only going to get worse/wear quicker.
A bit worrying. Looking at it I would change the cam. even if it does not cure the misfire.
Does it just mis or backfire or spit through the throttle body??
A backfire would point to the exhaust valve a spit back to an inlet valve ( cross reference that) with the cam lobe for said exhaust or inlet valve and it may be a pointer,
ETA in pic 3 there looks to be like a line going right down the centre of the cam lobe. could be a trick of the light or a surface crack in the cam hardening.
[Edited on 19/7/10 by omega 24 v6]
mookaloid
posted on 19/7/10 at 04:59 PM Reply With Quote
I think you might just have caught that cam just in time before it completely wrecks the engine.
You certainly don't want to start the engine again until the cam is replaced and the oil and filter changed.
You might just find that the misfire goes when you have done all that work - if not then you know it wasn't the cam!
Mooky
posted on 19/7/10 at 06:09 PM Reply With Quote
Looks like a symptom not cause.
Cause is likely to be oil related --- good quality 5w/30 semi-synthetic or fully synthetic required.
Cam & followers need to be changed PDQ.
A magnetic drain plug should help catch any debris that can't be cleaned out.
[Edited on 19/7/10 by britishtrident]
Mark G
posted on 19/7/10 at 06:13 PM Reply With Quote
Thats unlikely to cause a misfire, Its just the case hardening coming away from the shaft. Especially as you've said the misfire is on no.2 and that looks like its on no.1.
I would replace it though as now that the hardened surface has gone it wouldn't take long before it's totally shot and also knackered your rockers.
What were the results of the compression test?
DRC INDY 7
posted on 19/7/10 at 06:22 PM Reply With Quote
A missfire happens a lot with the latest nissan micra engine when compression tested there is up 30% difference in the compression results always caused leaking valves requiring head off and valves re lapped in
Then after that is done it has to go on the computer to re learn the values fro idle etc
[Edited on 7/19/2010 by DRC INDY 7]
Puddle Dodgers Club
perksy
posted on 19/7/10 at 06:34 PM Reply With Quote
That wouldn't be the first Ford KA to eat a Camshaft
Also The Early ones had abit of a reputation for Camshaft/Follower issues
That and Sparkplugs that has a habbit of seizing in the head
Needs Changing ASAP
What were the Compression readings ?
Out of interest what did the plugs look like when you changed them ?
[Edited on 19/7/10 by perksy]
RichardK
posted on 19/7/10 at 06:44 PM Reply With Quote
Ooops, thats reminded mookaloid!
Gallery updated 11/01/2011
iank
posted on 19/7/10 at 06:47 PM Reply With Quote
Needs Changing ASAP
Is that not a completely different engine to the one in the SportKa? (OHV Kent derived vs SOHC all alloy).
Anonymous
Liam
posted on 19/7/10 at 06:48 PM Reply With Quote
Have you cleaned that camshaft? Could be just the photos, but looks as dry as a witch's ****. Had the covers of my tintop recently and it all looked a lot more oily in there! Oil starvation might explain why it's gone all blue and started pitting/spalling! Does it get serviced properly?
mookaloid
posted on 19/7/10 at 06:58 PM Reply With Quote
indeed - fortunately on this occasion the garage sorted it out at their expense
beaver34
posted on 19/7/10 at 07:05 PM Reply With Quote
gap the plugs make sure there right, did you use genuine parts for it?
is it bad enough to bring on the engine light?
posted on 19/7/10 at 07:30 PM Reply With Quote
As said the worn cam is on no 1 cylinder, if you have changed the plugs, coil pack and swapped the injectors around then I think a cylinder leakage test would be a good idea followed by a good look for inlet manifold air leaks especially around the inlet for no2 . It may also be a good idea to test for power supply at the injector using a Noid light or digital voltmeteras voltage at idle may be a bit low?
Liam
posted on 19/7/10 at 07:54 PM Reply With Quote
I count damage on at least 3 cylinders in those photos - wouldn't be surprised if it's all of them. Has to be oil starvation. Possibly just poor servicing over a long time, maybe even before the current owner - 80,000 is fairly high for a cheap little car/engine. Sticking valves could also damage the camshaft and might explain the misfire. Another pointer to lubrication problems or maybe overheating which could itself be a symptom of poor lubrication or a water cooling problem.
tegwin
posted on 19/7/10 at 10:27 PM Reply With Quote
My mother had the car from new.... It was serviced by Ford... and since then, by me....
Yes, I cleaned the oil off the cams so I could photograph the damage...
Its currently driven by my sister who in true 'woman' fasion never checks the oil.... but I have never done a random inspection and found the oil to be unacceptably low.... There is a whining noise sometimes from the belt/chain side of the engine... I had assumed it was a sticky waterpump seal... I do wonder now if its an oilpump fault?!??
The pitting/damage of the hardening is on all lobes, the intakes are much worse than the exhauast...
Interestingly Cyl2 exhaust is the best one...whish is odd given that is where I suspect the fault is...
I cant work out if its worth fitting new camshaft/valve-regrind...... the car cant be worth much more than £2k.,.. if that...
Anyone care to guess how much parts would be for a new camshaft/follower/lifter set?
