Author: Subject: Big end bolts
midge
posted on 4/8/10 at 01:26 PM Reply With Quote
Big end bolts
Hi all,
I'm replacing the piston rings on my sons Corsa and wondering whether or not the big end bolts can be reused.
Any thoughts / comments appreciated.
Dusty
posted on 4/8/10 at 02:24 PM Reply With Quote
Haynes says probably new bolts needed. Torque depends.
SOHC with 15mm thread length = 18ft/lbs. OLD bolts reuse.
SOHC with 40mm thread length = 18ft/lbs then 30 degrees. NEW bolts.
DOHC is also 18ft/lbs and then 30 degrees. NEW bolts.
[Edited on 4/8/10 by Dusty]
Ninehigh
posted on 4/8/10 at 04:10 PM Reply With Quote
How expensive can these bolts be? Sod it get them replaced
