big_wasa
| posted on 5/8/10 at 08:35 PM |
locost trailer deck ideas
I am cracking on with the locost trailer transporter project.
I need to get it finished and moved before the pikies come back around
What to use for the decking ?
needs to be cheap-ish and able to with stand the weather.
your ideas please.
PSpirine
| posted on 5/8/10 at 08:37 PM |
Plywood? External grade should do the job - marine if you got the monies.
2cv
| posted on 5/8/10 at 08:40 PM |
I've used Stirling or is it Sterling board on my trailer. Every so often slosh some creosote over it and when eventually it rots replace it. Its
very cheap and durable. I have thought of but never done it is to place a piece of galvanized 1mm steel over the top which would extend its life many
times.
MakeEverything
| posted on 5/8/10 at 08:41 PM |
Weld some angle in for the tyres. Thats all you need
Kindest Regards,
Richard.
Humbug
| posted on 5/8/10 at 08:50 PM |
Isn't welding galvanised a no-no?
big_wasa
| posted on 5/8/10 at 08:53 PM |
I have ground the galv of where ive been welding and doing it out side.
blakep82
| posted on 5/8/10 at 09:19 PM |
Some of those aluminium ramps you can get? Bolted down?
________________________
will121
might not be totally locost but for a do it once job this ali punched decking seems a good price £63+vat 2500mm x 610 wide
punched decking
blakep82
Dangle_kt
| posted on 5/8/10 at 09:24 PM |
What about some of those aluminium ramps you can get? Bolted down
mangogrooveworkshop
| posted on 5/8/10 at 09:25 PM |
Wooden tanilised Decking works......doesn't make it to flashy ....
If its to fancy it will disappear....trust me on that one
MakeEverything
| posted on 5/8/10 at 09:30 PM |
It produces Cyanide, but ground off as said, and outside should be ok as long as you dont breathe any in.
Kindest Regards,
Richard.
blakep82
| posted on 5/8/10 at 09:49 PM |
shut it! my phone went a bit funny
[Edited on 5/8/10 by blakep82]
rick q
| posted on 6/8/10 at 03:51 AM |
Galvanized wire mesh on mine, with aluminium sheet where the tyres sit :-
