r1_pete
| posted on 10/8/10 at 07:26 PM |
Son in Law tin top woes - Astra 2.0 TD
Son in law's 2001 astra just blew its turbo bearings and squirted the contents of the sump down the exhaust.
Have found a replacement from a 30,000 miler, just wondering if anyone has changed one, and if there are any gochya's, looks fairly
straightforward, but, as usual any advice greatfully recieved.
bob tatt
| posted on 10/8/10 at 07:32 PM |
you may need to get a new cat if there is one fitted as this will be toast as well..
SteveWalker
| posted on 10/8/10 at 08:21 PM |
It didn't overspeed and damage the engine did it?
Diesels are notorious for running out of control on their own lubricant, often 'til they self destruct. They'll also run on any
combustible vapours in the atmosphere - hence diesels working in refineries and chemical plants have air inlet cut-off valves to allow them to be
stopped.
dinosaurjuice
| posted on 10/8/10 at 08:40 PM |
diesels dont need cats, although most are factory fitted with them. They are only smoke tested at MOT's.
[Edited on 10/8/10 by dinosaurjuice]
r1_pete
| posted on 10/8/10 at 09:00 PM |
Thanks chaps, it will run on but hasn't revved itself to death, he got it home and it wouldn't switch off, so he easily stalled it. Its
probably driven 2 or 3 miles since the turbo bearing noise started, fortunately he's no boy racer and drives very sedately.
We'll see what the weekend brings when I pull it apart.
