Author: Subject: Wanted DCOE 40 spindle
JeffHs
posted on 9/9/10 at 06:56 PM Reply With Quote
I'm still struggling to make the 40s work properly. I can't balance the carbs, I've concluded that 1 of the spindles must be twisted because the throttle valve in #1 barrel is open more than the other 3. If I peer down the progression hole opening daylight is visible in #1 but not #2, 3 or 4. I've spent a few hours fitting and fettling and it's better but I don't think it will improve until I change the spindle. I just can't drop the idle speed sufficiently to set up the idle circuit.
The car is transformed above 2500 rpm but is rough below.
Can't find one anywhere for sale on web. Has anyone got one lying around?
Don't want to go back to the DGAV if I can help it but also don't want to spend a small fortune on new carbs
Jeff
r1_pete
posted on 9/9/10 at 08:05 PM Reply With Quote
I have one you can have, will post some pics up tomorrow evening, to make sure its correct for your carb.
JeffHs
posted on 9/9/10 at 08:13 PM Reply With Quote
Great Thank-you
r1_pete
posted on 10/9/10 at 04:45 PM Reply With Quote
Here you go......
Image deleted by owner
