Author: Subject: More Snake oil for your cars?
AdrianH
posted on 10/9/10 at 10:03 PM Reply With Quote
I know I should be less cynical about these things but this ebay thing is no more then a capacitor and considering the smoothing effect of a decent battery cannot see it myself.
Still some must believe in it!
Lin ky
Adrian
Why do I have to make the tools to finish the job? More time then money.
ReMan
posted on 10/9/10 at 10:17 PM Reply With Quote
youd get better results reducing the weight of your car by burning some money out of your wallet
Doctor Derek Doctors
posted on 10/9/10 at 10:19 PM Reply With Quote
Its like a tax on stupidity.
gavin174
posted on 11/9/10 at 12:07 AM Reply With Quote
For your confidence to try this product,
we provide a full refund warranty.
If you gain no profit after installed this item,
you can return the item and get back the payment and postage.
We will also handle the returning postage
posted on 11/9/10 at 09:09 AM Reply With Quote
hmmm, there is some scientific fact behind this. having a capacitor, which is almost certainly what this is, near the igntion coil, (almost ceretailn where this would be fitted to avoid the long wires from the battery) to supply extra current on demand is not a bad thing and will give more power to the coil.
... .but I cannot see it making any noticeble difference, most modern alternators will already have suppressor (capactiro) built in.
Mal
posted on 11/9/10 at 09:14 AM Reply With Quote
Snake oil of the most slippery kind!
Neville Jones
posted on 11/9/10 at 11:20 AM Reply With Quote
IF that is a capacitor, then you would see any benefits on an oscilloscope. We used to put a big cap on the ignition side of the coil on the boys' grasstrackers, and it made a big difference at high revs. There was no breakdown or missing. And you COULD see it on the 'scope. Much smoother and lower voltage fluctuations. But, it had to be attached directly to the coil.
What it would do at everyday driving revs I don't know, the engines we ran this on rarely ran below 6k. Increased fuel mileage? You'd have to be using a fairly poor ignition system to make that much difference, and you'd certainly notice it.
Nev.
AdrianH
posted on 11/9/10 at 02:18 PM Reply With Quote
But the user says connect directly across the battery, not across the coil or ignition amp etc.
Adrian
paulf
posted on 11/9/10 at 02:54 PM Reply With Quote
It also says that it improves diesel consumption by improving the re compression ? of the engine.
Its obviously complete BS as with the other similar items such as heavy gauge fuel pump supply cables , resistors, h202 kits etc.
Paul
posted on 12/9/10 at 08:57 PM Reply With Quote
Adrian
yep - I saw that after I posted. hmmmmmmm
Badger_McLetcher
posted on 13/9/10 at 12:33 AM Reply With Quote
I call bull crap. Complete and utter.
Liam
posted on 13/9/10 at 09:49 AM Reply With Quote
As with all of these stupid resistors, magnets, windmills and electrolysis kits, if they gave the slightest bit of benefit they would all be standard parts of the latest Ford Fiesta, and Ford would be advertising its amazing class leading performance and economy. At least until all the other manufacturers fitted them to their models too.
No wait I forgot - Big Car is in cahoots with Big Oil to keep cars inefficient so we all buy lots more fuel, right? Sigh... Facepalm
Of course there will always be the odd application, such as what Neville describes, where a standard system is essentially faulty, either from deterioration with age or just initial poor design, where one of these devices actually does make a difference by improving the situation, but anything relatively modern that works will be unaffected or even made worse.
[Edited on 13/9/10 by Liam]
