DaveFJ
posted on 13/9/10 at 08:46 AM |
I'm a bigger idiot!
Just had to let you all in on my huniliation...
I use a moped to get to the train station in the mornings (i know - thats humiliating enough already!)
i was trying to replace an exhaust stud and broke part of the mating flange off so had to strip the bike completely and re-weld the flange....
got it all back together and the damn thing wouldnt start
pulled it apart again and check sparks etc - all seemed good....
(can you guess where were going yet?)
started checking fuel pump and appear not to be getting any fuel through..... so started to strip and check fuel system.... couldn't find a
fault....
It was about this time my 17 year old daughter asked me if i had checked it had any petrol in it.......
Dave
Ben_Copeland
| posted on 13/9/10 at 08:48 AM |
Yeah you are an idiot lol
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
eddie99
| posted on 13/9/10 at 08:54 AM |
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Humbug
| posted on 13/9/10 at 08:57 AM |
Yes, you are a total ().()
pekwah1
| posted on 13/9/10 at 09:04 AM |
if it makes you feel better....
back when i had a stupid turbo nutter japwagon, i was out driving and the car starting making some stange noises and then was cutting out on boost.
I decided to take it back home, checked it all out and couldn't see anything too wrong. Assuming it was a turbo issue, i took the turbo off and
was checking the whole boost system, all looked fine....
Anyway, after 4 days of stripping bits off the engine it finally occurred to me i also had no fuel in the car!
what a div i felt!
FFTS
| posted on 13/9/10 at 09:17 AM |
So that's what I need to do to be able to drive it then!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks for the tip
Chris.
| posted on 13/9/10 at 10:05 AM |
I believe it was your full and thorough safety precautions in removing the fuel prior to welding
mad4x4
| posted on 13/9/10 at 11:28 AM |
I had similar - Spent weeks trying to get the MK Indy to run using megasquirt to eventually find out that the fuel pump was making a noise but not
pumping...... Had always assumed it was pumping because I got the noise.
New pump sorted that one
Scot's do it better in Kilts.
phelpsa
| posted on 13/9/10 at 12:05 PM |
We've all done it. The old fuel line I had in the 205 would perish at the ends so the fuel pump would suck on air. When I came to start it in
april there was no fuel coming through (you can see where this is going), took the fuel line out, couldn't find anything wrong with it. Then I
realised I'd left it with an empty tank before the winter... oooops!
mangogrooveworkshop
| posted on 13/9/10 at 01:11 PM |
at least i wasnt diesel.....in the tank.
Someone gave someone else a tank with petrol in it.......it also had a lot of water in it.
It go stuck in the tank and on the way back from forresburn....the car stopped......water everywhere........doh everywhere it shouldnt have been
Canada EH!
| posted on 13/9/10 at 03:38 PM |
The unfortunate part is that your 17 yr old daughter will store this in the memory bank and use it later in life.
