Norfolkluegojnr
| posted on 6/10/10 at 09:31 PM |
At last! Collected the new project .....
Drove excellently, well chuffed with the whole car. perhaps a bit firm for the road, but should be awesome on track. Pics below including
Norfolkluego, and the beautiful evening we just had.....
Am i in the gang officially now?
matt.c
| posted on 6/10/10 at 10:08 PM |
Is that a hill behind you?
We dont have hills around here
Nice car BTW
Madinventions
| posted on 7/10/10 at 12:21 AM |
A hill? No, that counts as a mountain in Norfolkshire! And take a look at the angle of descent on the driveway - it's like a cliff-face!
<ahem>
So will we see you at the Diss meeting on Sunday?
Ed.
View my band website:
http://www.shadowlight.org.uk
Dopdog
| posted on 7/10/10 at 06:15 AM |
looks great more info engine?
pekwah1
| posted on 7/10/10 at 07:58 AM |
jealous! i've got one of those but don't doesnt drive yet...
Norfolkluegojnr
| posted on 7/10/10 at 08:17 AM |
Its a 1600 CVH with twin 45's and a race cam.
I was quite suprised how well it went at the top end, a fair bit more pokey than the original crossflow in dads Luego.
Zetec conversion is on the cards eventually, but for now i'm going to try and enjoy the beast as it is.
Might need to wing the suspension down a bit as i'm pretty sure its sprung for track, as my spine is a bit bruised
Need some good weather now!
mangogrooveworkshop
| posted on 7/10/10 at 12:02 PM |
At least its the right colour....and but some ones stuck a big piece of paper on the nose.....
Werner Van Loock
| posted on 7/10/10 at 06:10 PM |
congrats on a very nice car, i'm a bit biased off course
But don't go zetec, go 4age, car is too small for a big lumpy zetec and 4age and striker are a perfect match imho
In my opinion there's only 3 engines suited for the striker: x-flow, 4age or bike all the rest is either too heavy, too big or too slow
here's a pic of mine with it's new cage:
  striker cage 1
[Edited on 7/10/10 by Werner Van Loock]
http://www.clubstylus.be
Norfolkluegojnr
| posted on 8/10/10 at 07:49 AM |
That cage looks awesome. Very well nailed together.
4age was the other option (i'm more a fan of CEC) but i know very little about them, and having done a zetec conversion, i'd be more
comfortable with the outcome.
Without starting a new thread, what are the basics needed for the change? i can reuse my 45's, and the car is on a type 9 which i think you can
get an adaptor bell housing for?
norfolkluego
| posted on 8/10/10 at 12:03 PM |
Molehill
Don't use the words 'new lawn' and 'molehills' in the same sentence when you're talking to him
Werner Van Loock
| posted on 8/10/10 at 08:36 PM |
you need a bellhousing from raw and possibly a hydraulic clutch slave + clutch.
A twin DCOE manifold for your carbs and a trigger wheel + megajolt and you're done.
And some plumbing off course.
apart from the clutch + bellhouse it's the same thing as the zetec conversion with same power output but in a much smaller and lighter
package.
My 4age live axle striker weights in at 500kg, maybe a tad more now with the cage.
[Edited on 8/10/10 by Werner Van Loock]
tul214
| posted on 8/10/10 at 08:41 PM |
I have an inlet for twin 45's if you decide on the 4a-ge conversion.
1.6 Raw Super6 sold
JimSpencer
| posted on 8/10/10 at 10:23 PM |
Hmm
I'm running 4age phase 3 16v and assuming we're talking speed events still, definatly wouldn't go for a normal Zetec as it would put
me up a class break (over 1.7L) and it would be outclassed in there..
Saying that don't know if I would go down the 4age route again either, to get up to 170ish bhp is easy enough and it belts along happily, but to
get more can be pricey.
The weapon of choice seems to be either the 1.7 Zetec SE (out of a Puma) which seems to get to around 200 ish for reasonable money (couple of folks
getting nearer 230 - 240 apparently but big bucks) or the 1.6 Vauxhall as that can be tweaked to around 200 ish too.
Saying all that of course the first point of call is make it handle right, there's normally more corners than straights
JimSpencer
| posted on 8/10/10 at 10:27 PM |
Oh and nice car BTW!
If it's a bit OTT in the springs dept, might be worth investigating a front ARB if it's not got one, before changing things..
Once you've got the roll under control you can then come down significantly on the spring rate - got this T shirt..
Made a huge difference to the on track performance plus your fillings stay in when it sees the street!
