Author: Subject: jaguar engines
david
posted on 10/10/10 at 07:49 PM Reply With Quote
jaguar engines
engines fitted to the jaguar xk are 4.00 or 4.2 lt. which is the best engine? Has any one done the gas conversion and is it difficult, or where is the best place to get the parts
marcjagman
posted on 10/10/10 at 07:59 PM Reply With Quote
For a gas conversion the 4.0 is best. Loads of DIY kits available. If I can fit one, anyone can.
mark chandler
posted on 10/10/10 at 09:53 PM Reply With Quote
Jag v8's have soft valves so you need to fit a kit which bleeds a little petrol with the gas. I fitted a vogas kit to my XK8 2 years and 60,000 miles ago, its been fine and very economical, I bleed 5% petrol.
Later 4.2's are the same engines but better, more rigid castings I believe but the same rule above applies. 75 litre tank instead of the spare wheel, gives me around 250 miles on fill up, can get around 65 litres from empty in it.
I took some pictures of the install if you are interested, Cheap motoring I spent ~ £1000 putting it in using all new bits.
[Edited on 10/10/10 by mark chandler]
david
posted on 10/10/10 at 10:38 PM Reply With Quote
would be delighted to see the pictires if you you would mind. Where did you get your kit from. david
mark chandler
posted on 10/10/10 at 11:01 PM Reply With Quote
Kit came from here
Send me your Email and I,ll mail a zipped file.
Regards Mark
Strontium Dog
posted on 11/10/10 at 07:29 AM Reply With Quote
Lots of second hand kits around really cheap. I paid £300 delivered for the one I'm fitting to my GT4 and it came with a half full toroidal tank of gas. I have managed to re use everything except the one short length of pipe from the filler nozzle to the tank! It will have cost around £305 with the extra pipe needed. Make sure you get a later sequential set up as they are more efficient but a little more work to fit. Although you can fit the kits yourself, If your skills aren't all that, have it checked by an engineer or a gas fitter.
Lots of info from these places
http://autogashelp.co.uk/default.aspx
http://www.lpgforum.co.uk/
http://www.tinleytech.co.uk/
http://www.autogas-lpg.co.uk
[Edited on 11/10/10 by Strontium Dog]
david
posted on 20/10/10 at 08:13 PM Reply With Quote
jaguar 4.2 supercharged
have the chance of a 4.2 v8jaguar supercharged.. Any one know of any problems if I wanted to convert to gas
andyw7de
posted on 22/10/10 at 09:43 PM Reply With Quote
The 4.2 Supercharged V8 is a fantastic engine. Ive got an XJR with this engine and it delivers masses of silky smooth power that just keeps flowing.
Im busy developing a manual conversion for this engine using Jags getrag box for a friend of mine
Speed is just a question of money !
How fast do you want to go ?
