marcjagman
| posted on 18/10/10 at 07:22 PM |
XR4x4 chip or 24v transplant?
I have a 1990 XR4x4 2.9 and wondering whether to look for a chip for the ECU or maybe put a Granada 24v lump in. What do you lot think?
ChrisW
| posted on 18/10/10 at 07:25 PM |
Chip will likely be a waste of time. In fact, they were k-jet weren't they? So won't even respond to a chip?
Cossie 24v conversion would be much nicer!
Chris
mcerd1
| posted on 18/10/10 at 07:31 PM |
the 2.8's are k-jet, but the 2.9's are EEC IV
but I still wouldn't bother tunning it - unless you find a TT twin turbo kit
[Edited on 18/10/2010 by mcerd1]
Mr G
| posted on 18/10/10 at 07:34 PM |
No that was the fitted to the 2.8 xr4i's and xr4x4's (and capri's/granadas) - There is the the odd one out of the bunch from the
granada - the 2.8efi
2.9's were EFI ford EEC IV.
NS Dev
| posted on 18/10/10 at 08:16 PM |
pretty much as above EXCEPT, they are great cars!! I've had a few, and they get close to the "one car fits all" in a way that
nothing else I've had does.
Cheap, tough as old boots, quick enough for day to day driving, tow loads, sleep in the back etc etc, I love em!
24v is not a 5 min job but well worth it, the 2.9 12v really needs forced induction to do much really.
marcjagman
| posted on 18/10/10 at 09:09 PM |
So all I need now is a 24v scorpio with the twin intake, after it a bit of reading it supposidly has a bit more grunt.
NS Dev
| posted on 18/10/10 at 09:31 PM |
cosworth BOA engine is the earlier type 24v, fitted to the pre-frogeye scorpios.
BOB is the later one with the dual length intake setup, fitted to frogeye scorps.
The BOB is the better engine, but you'll need aftermarket ecu to run it. You can separate the BOA engine loom out from the rest of the car and
keep the eec4 ecu with that, but I would go BOB and fit an aftermarket ecu. If you went for an emerald K6 I know that Dave Walker has maps ready to go
for them as we did one in a capri not so long ago.
They make around 250hp completely standard on aftermarket ecu with no airflow meter.
ChrisW
| posted on 18/10/10 at 10:34 PM |
You're quite right. Having thought about it, I remembered. The 2.9s had a different plenum and dual air flow meters.
XR4x4 with a Cossie V6 is deffo on my list of cars I'd like in my 'collection'. Afterall, I've got an XR2 and an XR3, so an
XR4 (x4) is the logical progression!
Chris
Chippy
| posted on 18/10/10 at 10:38 PM |
I have the BOA fitted, running MS with BOB cams and Vectra injectors, makes 238bhp and 250lbs on a good day, plus on a good day it does 20 mpg, :-(.
Were I to do it again, I wouldn't, there are plenty of four pots that will give more power and use less fuel, Saab 9000 springs to mind, among
others. IMHO Ray
mcerd1
| posted on 19/10/10 at 07:52 AM |
http://www.maddoldbugger.supanet.com/
