will121
| posted on 29/10/10 at 02:11 PM |
just been to Emerald to have my ECU mapped 173bhp
finally been and had the Emerald ECU setup on RR, great service and a smooth 173BHP, im happy with that and the power spread. From graph still going
up and making power when hit 7000rmp which i said was my safe limit! leaves me scope for pub talk i can always say would have continued to go up to
200 at 8000rpm
2litre silvertop, GSXR750 ITB's and Newman 270 cams
| posted on 29/10/10 at 02:41 PM |
Nice! Wierd AFR graph though?
matt_gsxr
| posted on 29/10/10 at 02:48 PM |
173bhp is a healthy figure. Any idea how much the cams gain you?
Did they comment at all on the AFR?
I would have plotted it on a 11-17 scale and on that scale it would be very lumpy. I guess if that is what the engine wants for maximum power at the
different rev points then it must be right.
I'm keen to learn from the pros as I only have a wideband sensor and no rolling road.
Matt
will121
| posted on 29/10/10 at 03:40 PM |
its what gave the power and to be honest AFR at each mapping point was fairly steady at 13.4, however there was a bit of an issue with the cheap ebay
fuel pressure reg I have which had problems with holding a steady/consistant 3 bar pressure. Dave Walker did say cheap ones can be iffy
will121
| posted on 29/10/10 at 03:44 PM |
hard to tell cams alone, 270 cams, DIY ported head and ECU gained about 25bhp and higher rev's.
austin man
| posted on 29/10/10 at 08:49 PM |
brother in laws 2 litre zetec with Emerald and Griffin type inlet made around 155 then with cams did 165.
Now has 199 after changing the cams fitting bike carbs as TB's and a bit of head work.
jeffw
| posted on 30/10/10 at 06:43 AM |
Nice figures. For reference my Blacktop with large valve head, port and polished, cams & Jenveys made 165 BHP & 146ft lb at the wheels
(equates to 207BHP & 183ft lb if you use 20% lossess). Mine redlines at 7700rpm with arp bolts.
