Project7
| posted on 7/11/10 at 12:46 PM |
Tin Top Decat Legality
I've got a tin top which was first registered in April '95. As this is before the August '95 cut off date does this mean I can fit
a decat pipe without fear of failing the next MOT or falling foul of the roadside emission tests?
Project
marcjagman
| posted on 7/11/10 at 01:01 PM |
NO. You can only legally remove a cat if the vehicle it's fitted to was manufactured before Aug 1992, after that date if it has one it has to
stay on from a legal point of view.
Danozeman
| posted on 7/11/10 at 01:08 PM |
As said above. The cut off is 92 for mot. BUT. Alot of cars still go through the test with no cat so you could cut a cat casing off and weld it
around the decat so it looks like it has a cat.
Dan
Project7
| posted on 7/11/10 at 02:43 PM |
Thanks chaps
