gavinpurvis
| posted on 12/11/10 at 09:38 PM |
sylva striker harness
Hi
what is the best way to fit a 4 point harness? do i need brackets or can i mount directly onto the rear frame?
thanks
pekwah1
| posted on 13/11/10 at 01:14 AM |
does your chassis not have the mounting points already?
i also have a striker and i have screw in eye holes for the harnesses, i guess if you had standard fittings on your harnesses then you could still
just bolt to the same place?
it's not a great photo but probably the best i have of the mounts.
The ones for the sides are similar but attached on the lower chassis mounts.
StrikerChris
| posted on 13/11/10 at 06:50 AM |
Mine went through sva(not iva,don't no if things have changed) with that setup.Hitler at the test station spent some time measuring and there
isn't much leeway.keep the cushion on the floor pretty thin!
gavinpurvis
| posted on 13/11/10 at 11:34 AM |
no it doesnt have mounts just ones for normal seatbelts
no sv issue car already registered just a change of belts for me.
cheers
pekwah1
| posted on 13/11/10 at 03:31 PM |
normal seatbelts as in like in a tintop?
That's weird on a kit car....
take some photos of the belt/mounts you already have and post up and i'm sure we'd be a lot more help....!
gavinpurvis
| posted on 13/11/10 at 03:54 PM |
ok i will
it has screw holes to put some plates on, however i have only seen eye bolt mounts like this and my belts are not that type? would drilling the frame
compromise the strength of the chassis?
pekwah1
| posted on 13/11/10 at 03:56 PM |
so why can't you just the standard type of belt fitting and instead of screwing in an eyehole, just put a regular bolt through?
