PSpirine
| posted on 18/11/10 at 09:49 PM |
My most random ebay purchase to date.
Not entirely sure what or why or how. Oh well, £3.30 is about half of what a poorly mixed G&T is in a bar, so nothing to cry about!
1938 compressor air tank/receiver museum piece? on eBay (end time 18-Nov-10 21:48:00 GMT)
*Edited to correct link
[Edited on 18/11/10 by PSpirine]
carpmart
| posted on 18/11/10 at 09:53 PM |
I wouldn't use it, will likely be very rusty from the inside out!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
clairetoo
| posted on 18/11/10 at 09:55 PM |
Why , when I read the title , was my first thought "what has scootz bought now...."
Its cuz I is blond , innit
Claire xx
Will weld for food......
blakep82
| posted on 18/11/10 at 09:59 PM |
yeah, its alright, but i wouldn't trust it as a air receiver. what are you going to do with it?
________________________
You can weight it in
NigeEss
| posted on 18/11/10 at 10:09 PM |
hillbillyracer
| posted on 18/11/10 at 10:20 PM |
It's even older than mine, which was tested in 1942 to 400lbs. It'll be fine for it's rated pressure (but 80lbs isnt much) if
it's not been left with water in too much, but there's a fair possibility that it has been so you need to get it checked to be safe. How
thick are the walls, mine are 3/8" so there's a fair bit to rust through just to make it as thin as a modern one. I've seen one
rust through & it just started to leak, no dramatic explosion,
I thought about using one to make a new wood burner for my workshop when the current one is getting done.
Humbug
| posted on 18/11/10 at 10:46 PM |
Take the plate off and polish it up to have as an ornament, then weigh in the tank. I don't think I would trust it to still be up to spec
SteveWalker
| posted on 18/11/10 at 11:38 PM |
It's easy enough to hydraulically test it - I did that on boilers at the local Engineering club a few times.
alistairolsen
| posted on 19/11/10 at 08:46 AM |
fill it full of water and put a foot pump on the top. Worst that can happen is it splits and you get wet.
My Build Thread
