Author: Subject: Tintop Hazed headlight
l0rd
posted on 21/11/10 at 12:20 PM Reply With Quote
I need to repair the headlights on my tintop. Due to ageing, they oxidized and now are Haze.
There are a few techniques on the internet.
The best stuff is supposed to be 3M headlight restoration kit but i cannot find one here in UK.
Has anyone done it before and what did they use?
RazMan
posted on 21/11/10 at 12:24 PM Reply With Quote
I used Meguiars PlastX. My Lexus headlights are notorious for going hazy and yellowish. This stuff works a treat and makes it all nice and shiney again. You have to repeat the excercise every few months.
[Edited on 21-11-10 by RazMan]
Raz
l0rd
posted on 21/11/10 at 12:36 PM Reply With Quote
Yes, this one is one of the recomended ones.
Doesn't it come with a UV additive to stop it (lengthen the interval period)so you should have to do it every few months?
RazMan
posted on 21/11/10 at 12:50 PM Reply With Quote
The original headlights have a UV coating but this just wears off over time. PlastX only takes a few minutes to do the job and it is a bit like T-Cut to use - I tend to do them when I wax the car (which isn't very often )
Raz
posted on 21/11/10 at 04:57 PM Reply With Quote
For the plastic lenses inside Mk1 Mondeo lamps an overnight soak in denture cleaner worked a treat --- I jest not.
posted on 21/11/10 at 10:13 PM Reply With Quote
I used Farecla G10 on my Yaris headlamps - very effective, and cheap as I had it on my shelf anyway!
bimbleuk
posted on 22/11/10 at 12:32 AM Reply With Quote
Yep did that on my mk1 Mondeo just before I sold it.
I used a soft polishing mop and polishing compound on my laguna headlight covers which failed the MOT. They thought I had replaced them when I took it back.
[Edited on 22-11-10 by bimbleuk]
