Author: Subject: The mondeo saga continues
Lars
posted on 28/11/10 at 12:56 PM Reply With Quote
For anyone who has not read the previous posts, I have bought a cheap mondeo as a runaround, one issue is it has had a bodged engine change to a silvertop. (which in itself is not a problem)
I have now spotted a couple of loose wires and closer inspection shows that the aircon compressor is no longer connected, both electronically and gas pipes.
Now as its a cheap run around I will not want to pay to have it reconnected, so will remove it instead.
However other than buying a shorter drive belt is there anything else to remove/disconnect?
(btw lesson definitely learnt, look at car before buying, no matter how cheap)
Davegtst
posted on 28/11/10 at 01:01 PM Reply With Quote
Why don't you just leave it as it is? If it's not electrically conected the pulley will just free wheel and shouldn't cause any problems.
big_wasa
posted on 28/11/10 at 01:06 PM Reply With Quote
If its working leave it alone.
redscamp
posted on 28/11/10 at 02:59 PM Reply With Quote
a shorter belt, 6PK1718 let me remove the compressor completely
(not a lot of room to get it out)
i was worried the compressor might sieze running dry.
2.0 silver top mondeo
zilspeed
posted on 28/11/10 at 03:15 PM Reply With Quote
If the clutch is never energised, the pump never runs.
Empty system means that the clutch will never be energised, so it's not a problem.
It's the first sign of an empty system or low refrigerant level.
Lars
posted on 29/11/10 at 01:19 PM Reply With Quote
Interesting. I too was worried that it would seize...
I think I will still go for the shorter belt, as I was just replacing the old belt and my motorfactor is happy to swap for a shorter one (6pk1713).
Will allow me too save some weight too.
Thanks all
