NS Dev
| posted on 14/12/10 at 12:37 PM |
Media Blasting at Retropower
Bit of an advert, but we're now all set up for in-house media blasting, trying to keep everything under one roof (previously it was done on site
but by mobile contractor). If anybody wants to get any blasting done then have a look on our website, or feel free to drop by when we're doing
some (phone first to find out when we're next doing some! ) to see for yourselves
if this is too adverty for this thread, let me know and I'll remove!
cheers
Nat
mangogrooveworkshop
| posted on 14/12/10 at 05:25 PM |
pity you are 8 hours towing away otherwise i would give you the p100 to do
MikeR
| posted on 14/12/10 at 05:43 PM |
Once blasted, can you zinc primer spray before undercoating & top coating?
NS Dev
| posted on 15/12/10 at 12:09 PM |
Yep, any spraying can be done as long as its from a "normal" gun (i.e. not a hot applied coating). We normally use Max Meyer Ecophos 2
component zinc phospate etch primer as a first coat. After that its up to the customer (and we don't have to use ecophos, its just the best
thing we've found so far! )
At some stage (i.e. when I can get one cheap enough) I will hopefully get hold of a Metco oxypropane-wire gun or similar so I can do hot zinc
spraying....................................
NS Dev
| posted on 15/12/10 at 12:10 PM |
yea bit too far! Not sure who's up your way, if anybody springs to mind I'll let you know!
