Author: Subject: Interference required on taper roller bearing cup housing
NS Dev
posted on 8/1/11 at 10:59 AM Reply With Quote
As a "rule of thumb" what interference is required on a taper roller bearing cup housing (50.292mm dia bearing cup)
I don't know the tolerances that the bearings are made to as they are not a std bearing in an "off the shelf" catalogue, so I don't know half of the limits info required!
Its an alloy housing btw
phelpsa
posted on 8/1/11 at 12:30 PM Reply With Quote
Look for something similar on the SKF website, then use their fit calculator. Been a godsend in some of my recent projects!
phelpsa
posted on 8/1/11 at 12:33 PM Reply With Quote
Just read that you dont know the tolerances. Makes it a bit more difficult with that calculator bit you can play about with it and see what sort of numbers you come up with.
[Edited on 8-1-11 by phelpsa]
v8kid
posted on 8/1/11 at 02:40 PM Reply With Quote
0.1mm per race tech article if heat shrinking
[Edited on 8-1-11 by v8kid]
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
richardlee237
posted on 8/1/11 at 02:58 PM Reply With Quote
On a taper roller bearing the bearing is preloaded, which in effect expands the outer track into the housing. normally a 50mm track is fitted with a light push fit.
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
NS Dev
posted on 8/1/11 at 08:11 PM Reply With Quote
phelpsa - cheers, yep skf page is useful, but yep, no good on this one as I don't know bearing tolerance. For my purposes I'd say its nominal as I don't work to single digit microns!! Gone for 0.05 to 0.08mm interference to nominal 50.292mm hole size, fingers crossed, sounds about right! Want to err on tight side as its alloy and likely to "beat loose" more than a steel housing. I think I could hold a range of 0.03mm on a lathe so hopefully the machine shop will agree!! Its for some alloy hubs, using manta front (or nova rear) bearings, hence the funny bearing sizes, good old GM!
[Edited on 8/1/11 by NS Dev]
