Author: Subject: Trailer Hubs...Best Place to Buy
grassracer
posted on 10/1/11 at 12:16 PM Reply With Quote
Anyone recommend the cheapest place to buy braked trailer hubs/suspension units and other general trailer components?
posted on 10/1/11 at 02:35 PM Reply With Quote
rphleisure on ebay seem quite competetive.
Also try towsure and autow for comparison.
rf900rush
posted on 10/1/11 at 02:38 PM Reply With Quote
Not used them yet, but seem reasonable.
LINKY
Martin
Mal
posted on 10/1/11 at 03:20 PM Reply With Quote
I got mine from this company
www.peaktrailers.com
I use 4 x ten inch wheels on my trailer and Peak machine a chamfer on the brake drums to allow the small wheel to fit over an eight inch drum, instead of the usual seven inch ones.
hughpinder
posted on 10/1/11 at 04:09 PM Reply With Quote
Scrap caravan base is the cheapest - I got suspension, brakes, wheels (tyres rotted - I was twitching in case of a blow out all the way home!) ,hitch, galvanised chassis(needed strengthening though as it relied on the floor that was shagged, but the front A frame part was good) for £100. Hitch and suspension are rated for 1280kg. See your local paper classified ads, and you'll probably have to look at a few before you get what you want. I spent about £20 on refurbishing the hitch rubber gaiter and suspension bump stops, as well as some labour/grease nuts and bolts I already had etc.... Obviously you then need the deck materal/lashing points/lights/sides/reflectors if you want them etc etc
Regards
Hugh
rallyingden
posted on 10/1/11 at 04:27 PM Reply With Quote
Trailertech ........... cant remember URL
Very helpful and knowledgable.
RD
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 10/1/11 at 04:35 PM Reply With Quote
http://www.trailertek.co.uk/
