omega0684
| posted on 26/1/11 at 10:28 AM |
anyone know what make this sensor is?
sensor linky
Al
matt_gsxr
| posted on 26/1/11 at 10:39 AM |
looks like expensive one.
Maybe EPT3100 ?
http://www.inscale-loadcells.co.uk/TX_4892_Industrial+Pressure+Transducers_EPT%203100_Pressure+Transducers.html
RazMan
| posted on 26/1/11 at 11:02 AM |
Nice bit of kit but needs a data logger to be fully functional - £95 too!
http://www.race-technology.com/
[Edited on 26-1-11 by RazMan]
Raz
mad4x4
| posted on 26/1/11 at 12:01 PM |
Looks like a industry standard Pressure transmitter - Even RS Components do them price varies with Spec and Material
Scot's do it better in Kilts.
omega0684
| posted on 26/1/11 at 12:43 PM |
+ VAT!
Hence why i would like to source a cheaper but identical part
omega0684
| posted on 26/1/11 at 12:59 PM |
Raz where does it say that it needs a datalogger to operate? In the description it says that the product is
"Suitable for the measurement and Data Logging of fuel, water, air and hydraulic systems"
Al
RazMan
| posted on 26/1/11 at 01:04 PM |
I may have misunderstood, but...
"There are 3 leads that come from the sensor: the red lead should be attached to the +5v supply from the Data Logging Unit, the black lead
should be connected to the ground connection and the white lead should be connected to an analogue input."
Actually, reading it again it looks like the datalogger is optional
Raz
Richard Quinn
| posted on 26/1/11 at 01:10 PM |
the output is "0.5 - 4.5 Ratiometric" which, reading other parts of the spec, is volts. You will need something to either display this
graphically or capture it. Either way, it would be more useful if the "thing" dealing with the output was capable of doing the real time
conversion to bar rather than having to tape a calculator to your thigh whilst driving.
