mcerd1
| posted on 3/2/11 at 01:49 PM |
OT - How much brake fluid for tin-top ?
I've been searching google to death, but I can't find anything
How much brake fluid will I need to fill my Mk1 Focus ? (bog sandard 98-01 non-ABS one)
-Robert
speedyxjs
| posted on 3/2/11 at 02:31 PM |
Just looked on autodata and just says dot 4. No capacity! Normally they are around .5 litres.
adithorp
| posted on 3/2/11 at 03:31 PM |
I don't think I've ever seen a brake fluid capacity liste for anything. Usualy 1/2lt...ish, but it depends how much you bleed through.
http://jpsc.org.uk/forum/
| posted on 3/2/11 at 03:49 PM |
500ml should do it provided you have no problems bleeding it.
mcerd1
| posted on 3/2/11 at 03:52 PM |
cheers everyone
I've got a 500ml bottle of super 4 (the stuff ford sell for the car) somewhere - might pick up another one before I start just incase...
[Edited on 3/2/2011 by mcerd1]
| posted on 3/2/11 at 05:12 PM |
If you are changing the fluid buy a Turkey Baster out of Sainsburys and suck as much of the fluid out the resevoir before you start.
Waiting for the turkey baster one liners.
mcerd1
| posted on 3/2/11 at 06:26 PM |
^^ I'm changing the front calipers, flexables and some of the hard pipes too so I'm going to loose alot - add to that the fluid is bound
to be at least 5 years old and its not going to be worth trying to save any of the old stuff
I've actually got some old metal syringes so no need for turkey basters.....
| posted on 3/2/11 at 06:38 PM |
To keep the master cylinder primed, top up the master cylinder to the brim then seal the over the open top of the reservoir with cling film held on
tightly with a rubber band to form a a perfect seal this will stop fluid loss when you disconnect the pipes.
