rayward
| posted on 17/2/11 at 08:26 PM |
bearing fit ?
if you had a bearing with 55.00mm outer diameter, what size hole would you bore to fit this bearing into ?
edited to add: into a mild steel housing
thanks
Ray
[Edited on 17/2/11 by rayward]
HowardB
| posted on 17/2/11 at 08:30 PM |
depends on the materials into which you plan to mount the bearing,.. but standard values for steel / aluminium etc are available on the bearing manf
www's
Howard
Mad Dave
| posted on 17/2/11 at 08:50 PM |
There are hundreds of fits for bearings/bores. It really depends on the application. What is the purpose of the bearing?
rayward
| posted on 17/2/11 at 08:53 PM |
its a lower headstock bearing on a custom bike frame , taper roller bearing 32006.
the frames been built for me, the stock has been bored to 54.6mm, hence the question before i call and complain !!
thanks
Ray
Mad Dave
| posted on 17/2/11 at 09:07 PM |
54.6 is way too small. You are looking at something like a P5 fit of -0.027 to -0.040
I'll check tomorrow when I have access to my standards library
