Author: Subject: Freelander problems can anyone help my sister in France
Lightning
posted on 1/3/11 at 04:46 PM Reply With Quote
had an email from my sister in Strasbourg today. can anyone suggest anything?
We bought a second hand Freelander and it has broken down - prop shaft broken front - ref lTAG000230 I think , so we need to replace this and I suppose the viscous coupling unit too;
( Dont laugh we bought it one day and it broke down the next). The prevois owners are mortified and are going to help with repair fees.
The garage here says the part will cost 2,300€ - I have found the same price on the site LandRover parts, http://www.land-rover-parts-shop.com/fr/ui/products.php?model=Freelander%201&engine=Td4%202.0%20Diesel&cattext=Front%20Axle&subcattext=Axl e%20Drive%20Unit&group=Axle%20Drive%20Unit&year=2002 which I think they must use. It has a french site hence why they use it I suppose.
Yet I have found other sites given to us by previous owners where the price is much less - reconditioned etc . http://www.bellengineering.co.uk/2.html / www.island-4x4.co.uk Sites that theyve use before for other parts
Can you give me any other ideas where else to find these parts, as you are always on the lookout for the best deal?? there is no way we can afford 2,300€!!
A swift reply would be welcome
thanks
Karen
steve m
posted on 1/3/11 at 04:56 PM Reply With Quote
Am i reading this right, the part on its own costs 2,300 euro ??
for a driveshaft ?
If thats the case then i am sooooo glad i dont own a Landrover !!
MK9R
posted on 1/3/11 at 04:58 PM Reply With Quote
My dad and I are Bell Engineering, i'll give you as much advice as you want, and can supply parts cheaper than anyone else you can find
Not sure from your description what has happened, if its the IRD/transfer box they are expensive and parts to recon are not cheap either. Give me a call/email and i'll help you out as a fellow LCB
[Edited on 1/3/11 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
steve m
posted on 1/3/11 at 04:59 PM Reply With Quote
And from a google search that part no is a transfer box at £969
T66
posted on 1/3/11 at 05:01 PM Reply With Quote
MK9R on here is your man.
T66
too late !! hahaa
posted on 1/3/11 at 05:04 PM Reply With Quote
Now that's the sort of assistance you're after!
Good old LCB
StrikerChris
posted on 1/3/11 at 05:11 PM Reply With Quote
I thought you could just ditch the prop and troublesome coupling and run front wheel drive on a freelander?
designer
posted on 1/3/11 at 05:13 PM Reply With Quote
Car parts are a silly price in France.
All the french I know buy from Belgium or Germany.
designer
posted on 1/3/11 at 05:23 PM Reply With Quote
Whereabouts are they?
PSpirine
posted on 1/3/11 at 05:32 PM Reply With Quote
Not suggesting this is the most cost-effective route, but I can see how much I can get a prop for through work with a staff discount (I don't think we have FL1 parts lying around the place anymore unfortunately). If you can get me the part number for the prop shaft I can find out.
Lightning
posted on 1/3/11 at 06:24 PM Reply With Quote
MK9R Austen
I will give Karen an email and get her to give you a ring. I'm sure you will do what you can for her.
I only have the info that she has sent to me. Probably best for her to tell you what is wrong herself.
BTW its Karen Franc
(She dosnt really deserve this agro as she has just finished Chemo)
MK9R
posted on 1/3/11 at 07:09 PM Reply With Quote
Originally posted by Lightning
MK9R Austen
BTW its Karen Franc
Ok cool.
She would have had an apt name in france a few years ago
Cheers Austen
RGB car number 9
www.trackace.co.uk
johny p
posted on 1/3/11 at 07:18 PM Reply With Quote
yeah you can just take the prop off and make it 2 wheel drive thats what i did with mine, its the propshaft centrifugal rubber thats expensive. about 1000 pound new to buy.
TimC
posted on 1/3/11 at 07:22 PM Reply With Quote
I can hear the conversation now: "Yes, Hi Karen. What is probably best, is that you scrap the Freelander and buy a nice GTM Rossa MKII... and guess what...."
I'm sure he'll be more help than that really. He's not such a bad chap.
Lightning
posted on 1/3/11 at 10:07 PM Reply With Quote
MK9R
posted on 2/3/11 at 07:17 AM Reply With Quote
eeeerrrm no?? If your referring to the vcu, these are a lot cheaper than the IRD and diffs. A failed VCU causes the damage to the IRD and diff, as does mismatched tyres and running low pressures.
Sometimes removing the prop and running in 2wd drive sorts the problem out temporarily if its the crown wheel thats gone, but all that actually does is stop the noise. The thrust bearing collapses allowing the crown wheel and piniion to spin over the top of each other, causing the noise, but debris from the resulting grinding can causes lots more damage that can't be rectified by just removing the prop. Also other parts of the IRD quite commonly fail which can't be rectified by prop removal.
Cheers Austen
RGB car number 9
www.trackace.co.uk
