omega0684
| posted on 1/4/11 at 03:35 PM |
My start up "vid's" are here: Finally!
well here you go guys, i said i'd post up when i got it started ! first link is the start up, second its a little bit of revving action
Start up Link
Running and Revving link
All comments welcome!
mads
| posted on 1/4/11 at 03:38 PM |
what was the issue in the end? sounds good and imagine once roller'd it'll be even smoother.
[Edited on 1/4/11 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
omega0684
| posted on 1/4/11 at 03:42 PM |
crank sensor too far from the trigger wheel, reduced the gap to half a mm and pow!
Had to make a few tweeks to the pulse width, fueling and spark angle but apart from that it wasn't too much bother.
Yazza54
| posted on 1/4/11 at 04:31 PM |
Looks smart, sounds tappy is that normal?
I'm unhappy cos I eat and I eat cos I'm unhappy
dlatch
| posted on 1/4/11 at 04:40 PM |
was thinking that it sounds very tappetty too
Daddylonglegs
| posted on 1/4/11 at 05:06 PM |
Me too, but mine is no orchestra so who am I to talk
At least yours ticks over, mine won't yet
[Edited on 1/4/11 by Daddylonglegs]
scudderfish
| posted on 1/4/11 at 05:16 PM |
That's bizarre, I would have never have thought you could get an RPM signal on the ECU but not enough to run the engine. Well you learn
something new every day
daniel mason
| posted on 1/4/11 at 05:31 PM |
not trying to hijack the thread, but is that a race technology dash 2? if so whats it like please? ive just ordered one
zilspeed
| posted on 1/4/11 at 05:43 PM |
Very clattery top end there chief.
The old Pinto gives the cam a hard life at the best of times.
Maybe best to pull the cam cover and double check you have the clearances right.
Something's amiss there and it's best caught soon.
jimmyd
| posted on 1/4/11 at 06:59 PM |
Yes deffo check your tappets and while you are at it make sure there is good oil feed down the spray bar.
J
omega0684
| posted on 1/4/11 at 09:02 PM |
the cam has double valve springs in it, they are not your normal tappets either, they are HD Tappets from Millington, wider & thicker, the cam is
out of a 2.4 pinto, very lumpy indeed!
The engine is out of the car now as the clutch isn't engaging! looks like the forks on the pressure plate are too long so it need replacing with
a normal pressure plate.
jeffw
| posted on 1/4/11 at 09:16 PM |
Yes it is and they are fine...
http://www.locostbuilders.co.uk/forum/30/viewthread.php?tid=152905
Ask me any questions on the other thread.
TheKingofBling
| posted on 5/4/11 at 02:54 PM |
they are not your normal tappets either, they are HD Tappets from Millington, wider & thicker, the cam is out of a 2.4 pinto, very lumpy indeed!
Defo needs the valve clearances looking at mate.
I hope my titanium padded followers are still in my millington head.!!!!
The ones fitted in yours are long pad kent cams followers, if anyone should know, its me, its my old engine, i built the thing.!!!.
DIRTY DOGG RACING
