Author: Subject: Anybody know about legalities for vintage commercial vehicles
NS Dev
posted on 18/4/11 at 09:50 PM Reply With Quote
We are looking at buying an Austin k4 1940's truck, restoring it, putting a jag aj6 engine in it and using it as a car transporter. It would weigh under 7.5 tonnes, but what would it require in terms of mot, plating etc etc??
Benzine
posted on 18/4/11 at 10:05 PM Reply With Quote
My '72 TK was class 7 (now class 4 as it's registered as a motorhome now) That'd be my guess but I'm not sure if the age of the austin changes things. Sounds awesome btw!
Edit: class 7 is 3000-3500kg, not sure why I had that in my head. HGV at a VOSA station then I'd guess. Lots of the adverts for older commercials say 'tax/MOT exempt' but I can't see any conditions on the V112 that would actually make them exempt
[Edited on 18/4/11 by Benzine]
NS Dev
posted on 19/4/11 at 07:24 AM Reply With Quote
aha!! Cheers for that, just looked into the exemptions and you are right, pre 1960 HGV's are mot exempt....which was nice!
No MOT and no Tax....ideal car transporter, just a shame about the inevitable 8-10 mpg it'll probably do!!
Agriv8
posted on 19/4/11 at 08:51 AM Reply With Quote
I think you may run into problems if this is being used " in conjunction with or for your Business " but thats only likley to come up if you are pulled by Vosa. But even then suspect you would get a warning before getting into trouble.
but might be talking a whole lot of twadle.
regads
Agriv8
NS Dev
posted on 19/4/11 at 03:10 PM Reply With Quote
Did wonder about that, think would go for it and see what happens. Technically would need a tacho unless there is an exemption on that too, must read tacho rules again ( argggh talk about deciphering!!!)
T66
posted on 25/4/11 at 09:15 PM Reply With Quote
Running a K9 for the business, would need a tacho and mot done at your local HGV test station.
If its used for "hire or reward" then the K9 would attract as above. Why a K9 , is it the 4x4 ?
What about this , less rot and looks much better.
1958 Chevrolet Truck like Apache pickup | eBay UK
Or if you want 4x4 , then try a GAZ66 - I know my Russian trucks, and a GAZ will go anywhere a UniMog will.
GAZ 66 military vehicle | Russian military | GAZ66 | eBay UK
posted on 25/4/11 at 09:18 PM Reply With Quote
If its registered as private you don't need a tacho, or a limiter
Truck I took my test in was registered as private, road tax was £165 which I sworn at it for and it didn't have a tacho.
Volvorsport
posted on 25/4/11 at 10:01 PM Reply With Quote
volvo c303 , straight six as std - portal axles also .
not cheap tho in this country .
www.dbsmotorsport.co.uk
getting dirty under a bus
