Author: Subject: A frames
LBMEFM
posted on 26/4/11 at 08:22 PM Reply With Quote
A frames
Just tried out my shiney new towing "A" frame, total disaster, off I went and as I turned the corner it slid across removing my front number plate and scratching the nose cone, opened up the angle and attached to the outer parts of the wishbone on the wheel side of the damper and it will not steer, just drags the car across corners. Finally I turned the connecting rods up the other way and suceeded in bending a steering arm. How the hell do they work, are they supposed to be free to move across the wishbone, if so it makesa hell of a mess of the powder coat. Help please or does anybody want to buy it.?
marcjagman
posted on 26/4/11 at 08:28 PM Reply With Quote
You fasten them to the lower arms tightly with the steering lock of, they do make a mess of powder coating, a trailer is much better.
LBMEFM
posted on 26/4/11 at 08:31 PM Reply With Quote
Thanks Marc, I know where you fasten them but are they supposed to move up and down the wishbone?
owelly
posted on 26/4/11 at 08:32 PM Reply With Quote
They need to be so tight on the bones that they can't slide side to side or positioned in such a way that they have nowhere to slide, ie up against the inner pivots. They will damage powder coat and paint. Make sure the front tyres are hard and the steering lock is off!
http://www.ppcmag.co.uk
macc man
I would say they are unsuited to seven type cars, you would be better with an ambulance type of towing trailer.
Seen one used for towing a tin top car and was up and down the pavement out of control. Dont know why they make them really.
Ben_Copeland
posted on 26/4/11 at 08:33 PM Reply With Quote
Barry,
http://towingaframe.co.uk/fitting-instructions.html
Have a read of this.
Ben
Locost Map on Google Maps
Enter Your Details Here
LBMEFM
posted on 26/4/11 at 08:46 PM Reply With Quote
Hi Ben
Thanks for that, how are you?, long time no hear from you, are you going to the BHP show at Lydden next Monday, I am going to be there with the MK.
Barry
plentywahalla
I used to use one of these many years ago. It was always attached to the chassis or subframe, never to the suspension arms.
It needs good castor on the front suspension to work as that is what 'steers' the towed vehicle. I suspect it is not really suited to a seven type as it needs a rigid fitting and a moving suspension component cannot provide that. Also wide low profile tyres never castor very well.
Ben_Copeland
posted on 26/4/11 at 08:55 PM Reply With Quote
Originally posted by LBMEFM
Hi Ben
Barry
Good thanks, I doubt i'll make it. Depends whats on for the family !
Ben
NigeEss
posted on 26/4/11 at 10:01 PM Reply With Quote
Use mine often on many different cars and always on the wishbones.
Never, ever had a failure.
