Author: Subject: Megasquirt free help here!
BaileyPerformance
posted on 12/5/11 at 10:29 PM Reply With Quote
Hello Everyone,
After supplying, fitted and mapping 40+ megasquirt ECUs on all sorts of engines i can offer help to any locost forum user struggling with Megasquirt
Forced induction specialist
First tuner to fit megasquirt and Jenvey's to a Hayabusa 2008 autograss car
Good luck to all petrol heads!!
spiderman
posted on 13/5/11 at 01:49 AM Reply With Quote
Hi there,
Just after some megasquirt advice. I have a 1300 crossflow which I want to upgrade. I've got a an edis system to go on it and will be putting bike carbs on it to start with but later on converting to fuel injection. Which Megasquirt version do you recommend and what is your opinion of the edis system?
Also have a cosworth turbo, opinions on Megasquirt for that one also or should I just bung in a chip in the ecu.
Finally do you supply component only kits or are yours all fully built. I am an electronics technician so building my own would not be a problem for me.
Many thanks.
Spider
matt_gsxr
posted on 13/5/11 at 03:35 AM Reply With Quote
That is a generous offer.
Any top-tips on fueling algorithms for a turbo charged ITB fitted bike engine?
Speed density doesn't cut it, blended might help but I am worried about how I can tune it. I have heard that alpha-N with MAP multiply can do the job.
Sage-like advice always appreciated.
Matt
p.s. I've got MS2 daughter card and am running ignition and fueling.
HowardB
posted on 13/5/11 at 06:49 AM Reply With Quote
I have plans for a mad experimental (?) 8 injector system on a silvertop zetec, four original ones, + the four that are in the bike throttles.
The aim being to bring the ITB injectors in only at high revs,......
So will be in touch nearer the time to discuss how best to do it.
thanks for the generous offer!
Howard
ashg
posted on 13/5/11 at 09:10 AM Reply With Quote
the real question is do you have access to a rolling road? and if so where is said rolling road located?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Bumble
posted on 13/5/11 at 09:44 AM Reply With Quote
Seconds on that!! I'd be interested.
coyoteboy
posted on 13/5/11 at 10:17 AM Reply With Quote
They seem to, and they're in Telford.
Nice to know people are starting to really support MS over here too, half the roads I called wouldn't touch MS when I first started tuning my 3SGTE.
mark chandler
posted on 15/5/11 at 10:41 PM Reply With Quote
Hello Matt
I run my turbo blade engine on ITB's with MAP only.
I data logged the MAP readings then grouped the table around the most used values which solved most of my tuning issues.
Regards Mark
