jacko
| posted on 14/5/11 at 06:24 PM |
Stinking wash wipe water
Hi all my tin top water stinks i have washed the container out lots and lots with a hose pipe 2-3 days later its back to stinking
has anyone got any ideas what i can put in the water to stop this
I was thinking of something like Milton the stuff you clean babes milk bottles with
What do you all think ?
ps I think it would be a big job to remove the water bottle
Jacko
westf27
| posted on 14/5/11 at 06:30 PM |
are you using a high quality screen wash additive ? My van use to stink of wee when I washed the screen.Cheap Halfords screen wash was to blame.Just
a thought
steve
555
r1bob
| posted on 14/5/11 at 06:32 PM |
try milton in your washer bottle run it through the pipes and leave it to stand a few day's,, same principle as flushing caravan water pipes
zilspeed
| posted on 14/5/11 at 06:33 PM |
Chemical smell or fungal smell ?
If the later, I would be tempted to flush everytihng through with bleach as that kills mould growth.
(After having temporarily detached the feed pipes to the nozzles and routing them to somewhere safe of course.)
If chemical, I guess you need to work out what it is first.
jacko
| posted on 14/5/11 at 06:43 PM |
My 3 year old Grand Daughter says it smells like cow poo
| posted on 14/5/11 at 07:09 PM |
Be careful, there was an issue with legionella in washer bottles
| posted on 14/5/11 at 07:24 PM |
I'd also recommend a decent washer fluid - we use Decosol, which is basically industrial meths with added detergent. It always seems to work
properly without any strange smells.
loggyboy
| posted on 14/5/11 at 07:44 PM |
Milton would disinfect, but I dont no how much it would actively clean, it may be better to try some bleach?
Then use this stuff as it smells super nice:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_220805_langId_-1_categoryId_229902
| posted on 14/5/11 at 07:58 PM |
Common problem , I would try flushing the washer bottle with hot water followed by some water purifier available from any caravan accessory shop .
Might be a bit better than Milton's ?
designer
| posted on 14/5/11 at 08:05 PM |
Bruclenz used by home brewers cleans brilliantly.
Ninehigh
| posted on 14/5/11 at 08:36 PM |
Vinegar?
ReMan
| posted on 14/5/11 at 08:41 PM |
I was amased when i replaced the pumps on the cinqecento botlle the the remaiing water and sludge basically smelt like sewage
Wahed our well aand bleached it to kill it
www.plusnine.co.uk
