PSpirine
| posted on 1/6/11 at 11:15 PM |
What's this called?? (Blanking outlets)
Right, either these bits are very hard to find or I'm having a brainblock as to what they are called!
I've got a 8mm outlet on a fuel tank that I don't need. I want a 8mm rubber blank to go over it (to be clamped with a hose clamp). I.e.
like a fuel hose but only a couple of inches long,and closed on one end.
Can anybody show me where I can get one of these?
It's just to have a neater solution than using a bolt clamped inside a hose
Canada EH!
| posted on 2/6/11 at 01:05 AM |
Put an 8mm brass plug in the outlet if its threaded.
snapper
| posted on 2/6/11 at 05:07 AM |
The only thing I can think off is the rubber blanked off thingy that goes on a Pinto water pump.
Most people use a short bit of hose with a bolt clamped in.
I eat to survive
I drink to forget
lotusmadandy
| posted on 2/6/11 at 08:51 AM |
I just used a short bit of hose with a bolt clamped in it.
my reasoning is that nobody is ever going to see it.
I might have one of the pinto waterpump blanks if you want it.
Andy.
adithorp
| posted on 2/6/11 at 12:26 PM |
Those are the only blanks like you describe that I can think of. However I doubt they're fuel safe.
I have the same problem and I'll just use a short length of fuelpipe with a plug (bolt) in it.
http://jpsc.org.uk/forum/
