Author: Subject: Under-Dash Cover?
Dick Axtell
posted on 9/6/11 at 06:03 PM Reply With Quote
Under-Dash Cover?
I've been advised that Locost - style cars must have some from of cover, to separate the passenger compartment from the space beneath/behind the dash panel.
Is this correct? If so, what material should I use? Was thinking thin MDF, covered with any leftover trim material might meet the need. Comments please.
Mark Allanson
posted on 9/6/11 at 06:10 PM Reply With Quote
I just used vinyl backed carpet held in place with automotive trim clips, passed SVA in 2005
nearly done
posted on 9/6/11 at 06:41 PM Reply With Quote
Recently went through my IVA with nothing to seal off the area above the passengers feet/behind dash. As long as all the wiring is secured and tidy and any bolt heads/sharp edges covered I cant see a problemb.
Cheers,sean
Dick Axtell
posted on 9/6/11 at 08:15 PM Reply With Quote
Thanks for the comments. I'll have to get down and intimate with this under-dash area, and check for potential sharp bits.
