posted on 16/6/11 at 02:44 PM |
VW Beetle H-Beam Suspensions... Again!
Right... so I've established how it works, but how WELL would they work on a super-lightweight car?
Yes, I know the H-Beam is a heavy burger of a thing (you can get ali ones which make it a little more decent) and the set-up is antiquated, but is it
really a million miles away from the levels of performance offered by the likes of a standard seven-style wishbone configuration?
It's Evolution Baby!
kipper
posted on 16/6/11 at 03:56 PM |
Hi scotty, Well IMHO it would look pants if you are using the single seater chassis, they dont look too bad if you have lots of bodywork at the front
to cover it. Again just my take on it.
Regards Denis.
Where did that go?
Bare
posted on 16/6/11 at 03:57 PM |
weren't those mandatory on Formula Vee cars.
Likely lighter contraptions than your Locost?
Ultimate suspension design?? Dunno ? Must be lotsa info on the design aspect... somewhere.
posted on 16/6/11 at 04:09 PM |
Regards Denis.
My direction may have changed (again) Denis! It's looking like the trike will be full-bodied now!
Basically, the VW suspension would be very straightforward to fit and I'm happy to upgrade to ali beams and use top spec dampers, etc. with it.
posted on 16/6/11 at 04:14 PM |
quote: Originally posted by Bare
... weren't those mandatory on Formula Vee cars.
They still are.
... likely lighter contraptions than your Locost?
Nah... the standard steel VW h-beam set-up would be about 30kg heavier than a Locost-style wishbone and upright. An ali h-beam would knock about 10kg
of that. Not really a problem as my trike should comfortably be under the 300kg mark. It could also do with a bit of weight over the front.
Kwik
posted on 16/6/11 at 07:13 PM |
best suspension setup is double wishbone with inboard shocks.
the VW running gear is what i would recommend though, VW beetles are extraordinarily simple, not many cars you can take the engine out and in again
within 2 minutes...
i believe is just a matter of 4 bolts (maybe 8) for the whole front end as well
if your going to chose that route couldnt you just find a second hand formula Vee? or leaton racing in ireland do a cheap kit i think... (might be
leaston racing..)
posted on 16/6/11 at 07:21 PM |
quote: Originally posted by Kwik
... if you're going to chose that route couldn't you just find a second hand Formula Vee...
Kwik
posted on 16/6/11 at 07:25 PM |
did you already come to that conclusion then? its been a long day and winks by some people mean different things to others... i would be careful
posted on 16/6/11 at 07:36 PM |
eddie99
posted on 16/6/11 at 07:37 PM |
Ah ha you listened to my u2u scott Go for it! use a FVee
Kwik
posted on 16/6/11 at 07:52 PM |
great minds think alike
and the leastone racing one isnt that much money...
