Ben_Copeland
posted on 29/6/11 at 06:43 PM |
Ford Galaxy White Smoke
My wifes car has suddenly developed a fault. Oh Ford Galaxy 1.9tdi 115bhp (90k on clock), very good service history. In fact the oil was changed
couple weeks ago
Lots of White/Blue smoke from the exhaust when rev'd and at idle.
I can hear a fast metallic spinning noise when its cold, which goes away when you rev it, but then comes the smoke.....
She thinks it down on power. I'm awaiting a VAG-COM reader to come in the post.
But i'm thinking its the turbo i can hear?
Is there any sure fire way of finding out, before i shell out £300 on a new turbo.
Thanks in advance, i'll never hear the end of it if i dont fix it yesterday :|
[Edited on 29/6/11 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Ben_Copeland
posted on 29/6/11 at 06:54 PM |
Checked water for oil and viser versa
Ben
Roadster
r1_pete
posted on 29/6/11 at 07:04 PM |
If it is the turbo the next symptom will be you're unable to switch it off, it will run on the engine oil as it bypasses the seals, which soon
fail after the bearing gets noisy.
Ben_Copeland
posted on 29/6/11 at 07:19 PM |
Yes, but i wont be letting that happen :| i dont want the engine to go with the turbo!
Ben
Roadster
dinosaurjuice
posted on 29/6/11 at 07:39 PM |
all symptoms would suggest turbo failure
posted on 29/6/11 at 08:05 PM |
Sounds very much like the turbo has gasped it's last. Remove the air intake hose and check how much radial play is at the compressor wheel -
I'll bet it a lot as the metallic noise will be the compressor scraping on the housing...
jase380
posted on 29/6/11 at 08:33 PM |
im with the above, sounds like the turbo, a tdci mondeo i had a few years ago had the same symptoms and it turned out to be the turbo that was fooked,
dont rely on a code reader picking up the fault though, my local ford dealer had the car for 3 weeks and couldnt find a fault, in the end told me to
take it away and let it develop.... hence i no longer have a ford !!
Ben_Copeland
posted on 29/6/11 at 08:47 PM |
Well the galaxy has a Vw engine in it, which is well known for this.
Mike I'll check for play, thanks for that.
I was hoping someone was going to say, oh it might be a hole in the air pipe? But once I heard the noise it's was almost certainly the turbo
Nearly £300 for recon
Ben
Roadster
spiderman
posted on 29/6/11 at 09:29 PM |
Yep turbo seals and probably bearings.
Spider
Brian S
posted on 29/6/11 at 09:56 PM |
Also check the wife hasn't put petrol in the tank, that can produce white smoke when mixed with diesel. That's what happened to me when I
did it by mistake. Got away with it by brimming tank with diesel.
norfolkluego
posted on 29/6/11 at 11:28 PM |
Had very similar symptoms on my Pajero, metallic rattle and very smoky, convinced it was the turbo but it turned out to be the AGR valve
craig1410
posted on 29/6/11 at 11:50 PM |
Just checking, are you sure the smoke is coming from the main exhaust and not the small exhaust from the auxiliary heater under the near side wheel
arch?
I had an Alhambra which had a problem with the auxiliary heater and it produced plumes of White smoke when the engine was cold. This is a common
problem.
If the smoke is definitely from the main exhaust then disregard my comments but otherwise let me know and I'll give you more details.
Craig.
Ben_Copeland
posted on 30/6/11 at 03:44 AM |
Hi Craig, I'm aware of aux heater but I don't think it can be with the noise from the bearing
Ben
Roadster
Ben_Copeland
posted on 30/6/11 at 03:47 AM |
Hi mate,
How did you tell it was the egr?
[Edited on 30/6/11 by Ben_Copeland]
Ben
Roadster
norfolkluego
posted on 30/6/11 at 11:11 AM |
Hi mate,
To be honest, I didn't. I was so sure it was the turbo I took it to the local garage, they diagnosed and fixed it.
It made a horrible metallic rattle just like a blown turbo and was very smokey, I'd certainly check it first, one hell of a lot cheaper than a
turbo.
Ben_Copeland
posted on 2/7/11 at 10:52 AM |
TURBO
Compressor wheel not only moves up and down, it also moves in and out
It never showed any signs of trouble before that day. BUGGER
Ben
Roadster
