Author: Subject: Silver to Black
stantman67
posted on 6/7/11 at 04:52 PM Reply With Quote
Silver to Black
Looking for a stock 2.0 zetec silvertop engine as a spare, but not many around, however there are loads of Blacktops! what are the practical issues of swapping silver top to black if I need to replace my engine?
macc man
posted on 6/7/11 at 05:17 PM Reply With Quote
Very little difference beetween them so an easy swap.
big_wasa
posted on 6/7/11 at 05:41 PM Reply With Quote
The water pumps are differant so maybe a little plumbing to do and an idler for the alternator belt.
wombat
posted on 6/7/11 at 06:24 PM Reply With Quote
Silver vs Black
A little way off for my build but here goes......
Intention was a silvertop on bike throttle bodies but finding the same supply issues for s/h motors.
Found several blacktop mondeos etc being scrapped with low ish milage but...
I have been told must get a silvertop with webers in order to pass emissions.
Truth is ???????????
Confused.wom
whitestu
posted on 6/7/11 at 07:17 PM Reply With Quote
You'll need a pre '95 silver top if you want to benefit from less stringent emmission requirements.
stu
paulf
posted on 6/7/11 at 08:27 PM Reply With Quote
The alternator bracket mounting holes are different, I think both engine mount holes centres are different and the water pump outlet is smaller and angled differently, you will also need an idler for the water pump drives the belt routes differently.
I found it worth the effort to change as the black top seems to run a lot better than the silver top did with no hydraulic lifters to cause problems.
Paul
