Author: Subject: hesitant tin top
foskid
posted on 22/7/11 at 10:39 AM Reply With Quote
hesitant tin top
Help please.
I need a bit of advice with my tiptop. I have a Yaris which normally run ok but lately it’s starting to have a problem. It happens when I start to move off from a stop at lights or junction etc, it hesitates and does not seem to want to go for about 3-4 seconds and then it picks up and the drives normally thereafter till the next stop. A local garage recommended changing one or more of the ignition coils @ £100 apiece but I’m a bit suspicious of this, anyone had experience with or got some thoughts on this.
RichardK
posted on 22/7/11 at 11:28 AM Reply With Quote
I'd be taking a look at the maf sensor then then the lambda sensor 2nd, on some cars you can disconnect the maf and it'll run a little richer but could give you a clue? May put a code onto the ecu so maybe check first!!
Rich
Gallery updated 11/01/2011
posted on 22/7/11 at 11:31 AM Reply With Quote
Coils wouldn't be my first suspect unless it is a known fault with this model. Coil & plug misfires tend to show up as misfires under any hard acceleration.
I would do an obd scan and apart from logged and pending faults look at the live output from the throttle position sensor, coolant temperature sensor and MAP sensor, if the car has a MAF look at the output from that.,
[Edited on 22/7/11 by britishtrident]
RichardK
I thought the yaris had coil on plugs so you may get lucky and see a coil tracking if you have a look in the dark??
posted on 22/7/11 at 11:53 AM Reply With Quote
After a bit of scratching around I found there appears to be a few occurrences of similar problems on Yaris models which are diagnosed as VVT problems related to the Oil Control valve (OCV) gumming up.
