Author: Subject: Aaaargh! Flat battery!
posted on 24/7/11 at 01:11 PM Reply With Quote
Been out for a really good run this morning - 2 hours round the Suffolk lanes & by-roads. Only down-side was the number of drivers coming the other way who preferred the middle of the road... so I put my headlights on to give them all an extra clue.
Got to my local pub, had a couple of beers, then wandered out to get in the car to go home... flat battery! I'd left my headlights on.
Fortunately the landlord had some jump leads and let me start using his car's battery, so that didn't delay me too long.
Next job - fit some daytime running lights so I don't need to use my headlights! I'd fit a lights warning buzzer, but on tin-tops they rely on the door being opened to trigger the beeper - "lights on + door open + ignition off = beep" - which isn't so easy on a Locost! Maybe I'll fit a 10-second beeper that works on "lights on + ignition off".
Nobody's fault but mine... Sigh...
[Edited on 24/7/11 by David Jenkins]
John Bonnett
posted on 24/7/11 at 01:42 PM Reply With Quote
Why not wire your headlight relay coil feed through the ignition switch? Maybe easier and must be cheaper than fitting running lights.
PSpirine
posted on 24/7/11 at 01:52 PM Reply With Quote
Yep, that's what I did on my mini - just wired the headlights through the ignition only. It's only the hazards that need to work with everything off.
It's quite rare you'd ever WANT your headlamps on without ignition.
big_wasa
posted on 24/7/11 at 03:19 PM Reply With Quote
Side lights should work with the ignition of aswell.
mad-butcher
posted on 24/7/11 at 06:01 PM Reply With Quote
FIA battery isolation switch
Ninehigh
posted on 24/7/11 at 06:06 PM Reply With Quote
I remember my Astra would buzz if I left the lights on without opening the door, as long as the ignition was off.
indykid
posted on 24/7/11 at 06:14 PM Reply With Quote
A couple of beers?
I hope they were halves
posted on 24/7/11 at 07:39 PM Reply With Quote
I'll have to go and look at my wiring diagram to see if I can wire the headlights from the switched circuit... I still fancy DRLs though, as they do help the car to stand out, possibly more than headlights. I'm still not totally sure whether they are a good idea for every car on the road.
A buzzer would be very easy to rig though, even with a 10 or 20 second operational delay.
Of course, the simplest solution is to remember to turn them off!
As for the beers - I didn't say how big they were! )
whitestu
posted on 24/7/11 at 08:19 PM Reply With Quote
+1
Stops anyone turning the lights on when the car is parked as well.
Stu
posted on 28/7/11 at 04:26 PM Reply With Quote
Too complicated...
I have now worked out that I need one short piece of wire, plus a £2 buzzer from Maplins - it's a tiny mod of the relay circuitry I set up for the security system. When I've finished I will get a beep when I turn off the ignition when the headlights are on (but not if only the sidelights are on - I may want to do that, and they won't drain the battery as quickly as the headlights).
steve m
posted on 28/7/11 at 04:40 PM Reply With Quote
+2
Its also another way of securing the car,
[Edited on 28/7/11 by steve m]
russbost
posted on 28/7/11 at 04:45 PM Reply With Quote
This
Is what you need!
RichardK
posted on 28/7/11 at 05:47 PM Reply With Quote
Russ do you have any of those for the back
Gallery updated 11/01/2011
posted on 28/7/11 at 06:08 PM Reply With Quote
Already thought about the DRLs - easy enough to do (may still do - and Russ's prices are appealing!). At the very worst it's a new length of wire and a relay.
This is the first time in umpteen years that I've had this problem, so I don't intend to perform major surgery to my car loom!
russbost
posted on 28/7/11 at 06:38 PM Reply With Quote
DRL's for the rear???
posted on 28/7/11 at 06:49 PM Reply With Quote
No - front! The original problem was dodgy drivers coming at me in narrow country lanes on my side of the road. I put my headlights on to attract their attention - hence my discussion of DRLs!
