Author: Subject: Removing underseal
flak monkey
posted on 9/8/11 at 10:26 AM Reply With Quote
Removing underseal
I would like to remove all of the underseal from my Camaro so I can see exactly whats going on underneath and make any future repairs a damn sight easier, with the intension of POR-15'ing the underside then waxoiling rather than reapplying underseal anywhere.
So whats the easiest way to do it? Bearing in mind I can't flip the car over
Sera
http://www.motosera.com
bartonp
posted on 9/8/11 at 10:36 AM Reply With Quote
Heat gun & scraper :-(
r1_pete
posted on 9/8/11 at 11:04 AM Reply With Quote
Yep, thats how I did the MG, and parts of the Jag I'm now working on, if you can heat the opposite side of the metal it works better, breaks the bond without softening the underseal as much, so a bit less messy too.
scudderfish
posted on 9/8/11 at 11:09 AM Reply With Quote
Pay someone?
ChrisW
posted on 9/8/11 at 11:18 AM Reply With Quote
It's a horrible, horrible job. Blow lamp and paint scraper in difficult spots and wire brush cup on the grinder for flat panels worked for me. It took a week of nights to do my mk2 XR2.
Chris
posted on 9/8/11 at 06:58 PM Reply With Quote
Try using a sharp wood chisel without any heat to start with. I usually find it the most effective method if the underseal is old and dry. Best of luck ,it's not a nice job and be careful , hot underseal hurts and sticks to bare skin!
flak monkey
posted on 9/8/11 at 08:36 PM Reply With Quote
Thanks for the advice. I know all about hot underseal having done my fair share of welding on old cars. I think its only had one coat, so will see how easy it comes off. Going to have a look at the weekend and see what it's like.
Sera
