neo2
posted on 16/8/11 at 06:27 PM |
Kliktronic & Proshift titanuim paddles, flatshifter set up
Ok Guys after the sale on my Bike engine kit car ive a few items available for sale and the first is an amazing bit of kit and works excellent
transforms the driving experience a massive amount..
Ok its Pro Shift Titanuim paddle shifter electronic type combined with klictronic's electric gear lever soleniod kit and ecu, also combined with
this little lot is Flatshifter pro set up for up and down shifts.
So in a nutshell you can.
1.shift up/down via steering wheel paddles
2.upshift without clutch (smoother than with clutch and less wear)
3.Downshift without clutch if you want to as downshift blipper blips throtlle for you
4.Down shift blipper so blips on downshift as soon as you move gear stick or paddle down
This kit works spot on and makes shifting up the box a millisecond job and proper smooth..
Kit wise
The flatshifter Ecu has just been upgraded to latest spec 2 months ago and not used since..
The flatshifter gear lever sensor red bit, has just been rebuilt and set up both done at flatshifter by John..
Flatshifter detail click here http://www.flatshifter.com/
PROSHIFT TITATUIM PADDLES speak for themselves basically but the specs are here and the details again working perfect and complete with a steering
wheel spacer if you want it.
http://www.proshift.com/index.php?option=com_content&view=article&id=96&Itemid=60
The klicktronic system will come with all stuff in pictures and working perfect i will also include the mounting blocks i used and stuff as they dont
come with it but might be of use to you..
details of this system are here http://www.kliktronic.co.uk/technical.htm
A VIDEO OF MY ROLLING ROAD SESSION USING THIS SYSTEM ONLY (THIS IS CLUTCHLESS UP AND DOWN SHIFTS USING PADDLES ONLY)
http://www.youtube.com/watch?v=qHH7FX9j2I8&feature=youtu.be
Fitting wise alot of this is plug and play into each other but you will need to connect a few wires and taylor make them to your installation, but all
the paperwork and manuals are here and its quite easy to fit...
PRICE WISE THIS KIT AINT CHEAP REMEMBER NEW..
FLATSHIFTER PRO (NEW) £690 inc vat
PROSHIFT TITANUIM PADDLE KIT £535 inc vat
KLICKTRONIC CAR KIT £599 inc vat
MODULE BOX (GREY BOX) £50 inc vat so we have NEW wise £1874 worth of bits here.....
Im looking at for £650 THE LOT....
barnsey1971@aol.com
07527 995726
neo2
posted on 17/8/11 at 08:34 PM |
pm's replied too
neo2
posted on 18/8/11 at 07:01 PM |
NOW SOLD
