AndyW
posted on 14/1/12 at 03:19 PM |
best type of insulating tape
Hi all,
Now I have finished all the wiring, I have to start to fix and route the wires. I have got several small sub harness's which I have had to make
and or extend. These are currently held together every 6 inches or so with a small wrap of tape. I want to wrap the whole loom to make it look great
and want to know what the locost thoughts are. Do I just use insulating tape, although I think it looks a bit messy. Or self amalgamating tape, or
fabric tape, or conduit and tape or,???
What have you guys used and what kind of results have you acheived?
Thanks in advance.
[Edited on 14/1/12 by AndyW]
t16turbotone
posted on 14/1/12 at 03:26 PM |
http://www.car-vision.co.uk/consumables/12798-wiring-loom-harness-adhesive-cloth-fabric-tape-19mm-x-25-metres-roll-220924463548.html
craig1410
posted on 14/1/12 at 03:35 PM |
This is what we used to use at Lucas Automotive Electronics to build engine test cell harnesses:
http://www.vehicle-wiring-products.eu/VWP-onlinestore/sleeving/sleeving.php
It makes a really neat, professional job and is easy to handle. Ideally terminate the ends with adhesive lined heat shrink sleeving but you can also
melt the ends with a soldering iron and wrap with a small amount of self amalgamating or insulating tape to keep them neat. It costs up to £1 or so a
metre but to my mind it is worth it.
Other option is the split convoluted harness wrap but it's not so nice to work with. I would advise against wrapping with tape because it
isn't so easy to run another wire should the need arise (and it sometimes does...). If you think that is likely then the split stuff is easiest
but you can usually push a new wire down the braided stuff too. You can also easily tap into an existing wire or gain access for testing or whatever
in the event of a problem.
I hope this helps,
Craig.
Edit: Just to add - for branches, the braided covering can be terminated around the 'Y' joint but getting a large piece of adhesive heat
shrink and placing over the joint. Then heat and use your fingers or pliers to squeeze the heat shrink together inside the top of the 'Y'
section. The sleeving will stick to itself with the adhesive and form a nice neat joint.
[Edited on 14/1/2012 by craig1410]
austin man
posted on 14/1/12 at 03:55 PM |
convoluted trunking taped at the spurs
AndyW
posted on 14/1/12 at 04:05 PM |
thanks guys...
posted on 14/1/12 at 04:39 PM |
Split conduit , cheap, neat ,easy to install wiring and remove at any time . Easier than spiral type and available in various sizes
scudderfish
posted on 14/1/12 at 04:48 PM |
Don't use insulation tape. If you ever have to pick the loom apart, it's a horrible job.
matt_gsxr
posted on 14/1/12 at 05:45 PM |
Amalgamating tape isn't too bad, but some of the stuff goes a bit gooey if exposed to oil/WD40 etc.
The nylon mesh stuff (as above) is the neatest, but you need to be able to thread over the end (finish with that gluey heat shrink as suggested).
With split conduit doesn't need you to get to the ends and is good enough for the OEM's, but (to my mind) doesn't look quite as
sexy.
MikeCapon
posted on 14/1/12 at 06:47 PM |
All the looms I've made (a few hundred) I've done with loom tape (strangely enough) which is non sticky. Heat shrink or normal insulating
tape on the ends. Job done.
